I saw that ubuntu mate 18.04 has included mate 1.20 and with that marco and DRI3 is present.
But on my machine i still get screen tearing on my laptop with ubuntu mate 18.04 with intel gpu and marco on, i see that DRI2 and DRI3 is active but marco still does not use DRI3: xdpyinfo | grep DRI
DRI2
DRI3
@crash - I’m sorry to hear that - that message shows up when the graphics card driver doesn’t support Xpresent (which is the library that makes DRI3 work with the window manager). I think there’s a way to get a functionaly intel GPU driver with support (either through a kernel modset, or an xorg driver, not sure which), but I haven’t explored that…
At the moment it doesn’t seem to be possible to fix this from within marco, so playing with the graphics card driver (or its configuration) is the only way
Thank you for the explanation, that is too bad actually i had really looked forward to get rid of the screen tearing in Mate But i will try to add a 20-intel.conf in Xorg.conf.d and use the intel driver instead of the xorg modesetting driver that is default and see if that makes DRI3 enabled by that driver and Xpresent will be happy.
Hey,
have you tried using Compiz or Compton via Mate Tweak? Do you really have an intel cpu/gpu or rather an intel cpu and nvidia gpu (Optimus) configuration?
@motivation hi i have tried compton, but i don’t like the shadow effects in virtualbox(makes the display darker but only when using virtualbox) that is has when it’s enabled. I have a intel i5 cpu and intel hd 5500 gpu so no nvidia/optimus configuration on this machine.
~$ marco --replace &
[1] 23296
Window manager warning: Log level 128: Name com.canonical.AppMenu.Registrar does not exist on the session bus
Window manager warning: Log level 16: XPresent is not compatible with your current system configuration.
~$ inxi -G
Graphics: Card: NVIDIA GF104GLM [Quadro 3000M]
Display Server: x11 (X.Org 1.19.6 )
drivers: nouveau (unloaded: modesetting,fbdev,vesa)
Resolution: [email protected]
OpenGL: renderer: NVC4 version: 4.3 Mesa 18.0.0-rc5
I have read in the ubuntu forum that modesetting should be used instead. I haven’t got around to it yet.
@crash I’m not presently running ubuntu mate on my machine (dell xps 13, intel kaby lake graphics), but I made an ubuntu mate 18.04 live usb (from the latest daily image) and booted it up and I see the same problem as you; there’s tearing and marco says xpresent is not compatible.
I’m currently running solus with mate 1.20 and marco/dri3/xpresent works perfectly there on the same machine, so it seems like there might be some ubuntu/ubuntu mate specific bug here.
Since you are using the Modesetting driver/dri3 and have libxpresent installed I don’t see any issues with the configuration on your end, and I can confirm your issue with a live environment
@bwat47 Thank you for taking time and try the ubuntu 18.04 live usb, and you are having the same problem with tearing on your end, so there is not something wrong with my setup that is good
But now i wonder what Solus does instead of what ubuntu mate, beacuse you are saying it is working good over there.
@Wimpy: ^^
Do you have any insight on driver differences between Ubuntu and Solus that could cause this? I can confirm the same issue on my end.
I’ll try to update my old lemu4 (where I developed the Xpresent integration) to 18.04 this week and see if it’s a release-specific issue, or a hardware-specific issue.
Seems the same as the ubuntu mate driver versions (with the exception of mesa, which I think would not matter as I don’t believe marco is using opengl)
Are there any news on that? Because today on my laptop I installed UM 18.04 Beta myself; I get tearing and the “Xpresent is not compitable with your configuration.” message as well.
Any news on this? I installed ubuntu mate 18.04 on my xps 13 9360 and installed all updates and there’s still tearing with the marco compositing (and the message about xpresent not being supported)
Is there any way to get this to work in ubuntu mate? Everything I’ve read indicates this should definitely work with the intel modesetting driver (and it did work for me on solus without issue on the same hardware)
