Hi!
I can’t upgrade from 18.04 LTS to 18.10
Error-message in terminal after typed “sudo /usr/lib/ubuntu-release-upgrader/check-new-release -q”
…same with “do-release-upgrade”
Error:
Failed to connect to https://changelogs.ubuntu.com/meta-release-lts. Check your Internet connection or proxy settings
I have MOTD.service disabled.
/etc/update-manager/meta-release:
default location for the meta-release file
[METARELEASE]
URI = https://changelogs.ubuntu.com/meta-release
URI_LTS = https://changelogs.ubuntu.com/meta-release-lts
URI_UNSTABLE_POSTFIX = -development
URI_PROPOSED_POSTFIX = -proposed
/etc/update-manager/release-upgrades:
Prompt=lts
Must I change Prompt=normal?
My Internet is working. I can visit “https://changelogs.ubuntu.com/meta-release-lts”
Please help!
I changed in “/usr/lib/python3/dist-packages/UpdateManager/Core/utils.py”
proxy_support = ProxyHandler({“http”: proxy})
to:
proxy_support = ProxyHandler({“http”: proxy, “https”:proxy})
Rebooted my system, typed in “do-release-upgrade”
Error-message:
No new release found.
Some idea?
I did run into one odd issue soon after installation but was able to recreate it. This is what I did:
- I encrypted my filesystem as part of the installation
- Once I logged in, I did a “snap refresh”
- I also did an “apt autoremove”
- On the next reboot I was presented with a splash screen where it hung and then it went to a boot loader command prompt.
Everything was fine when I didn’t encrypt but I’m guessing if I didn’t do the autoremove I probably would have been ok. All that said, great job devs! Ubuntu Mate is, as far as I’m concerned, the best distro out there.
@Wimpy… I installed 18.10 on my wife’s laptop. She loves it. Great job guys!
