I'm trying to install Ubuntu-Mate 22.04 LTS on my asus laptop (celeron processor N4500, 11th generation). but i'm facing a problem in the last stage of installation.
The problem is found 'PTE read access is not set'
How can I solve it?
Hello Morshed
I am not an expert with regard to this kind of problem. That being said, a search on the Internet makes me think that this is a hardware related problem. The only thing I can sugest you try is to go into the BIOS options and change the settings for "virtualisation" support. Just alter any settings one at a time and try re-installing.
