Ubuntu MATE boots into emergency mode
I am communicating thru my cell phone. I have to because UM on my my pen drive will not use my USB connection to my desktop computer using my cell phone. (Subtle hint to developers.)
Hi, @fixit7
@ericmarceau is trying to help you in the following other topic that you've opened (I've edited the title of that other topic that you created, to change it from just "Having fun today" to "Having fun today (but boot is stuck in black screen)", because a topic with a title that just said "Having fun today" would probably not get noticed by many people):
Please, follow up / reply in that other topic. Thanks.
# I need this to be booted to
The version on sda2 does not work. It goes to emergency mode.
Can I merge the space in sda2 into another partition?
I also installed Grub Customizer.
menuentry 'Ubuntu 24.04.2 LTS (24.04) (on /dev/sda6)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-1f1ca355-c825-414f-98d0-09b81820edf4' {
	insmod part_gpt
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  set have_grubenv=true
  load_env
fi
if [ "${initrdfail}" = 2 ]; then
   set initrdfail=
elif [ "${initrdfail}" = 1 ]; then
   set next_entry="${prev_entry}"
   set prev_entry=
   save_env prev_entry
   if [ "${next_entry}" ]; then
      set initrdfail=2
   fi
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function initrdfail {
    if [ -n "${have_grubenv}" ]; then if [ -n "${partuuid}" ]; then
      if [ -z "${initrdfail}" ]; then
        set initrdfail=1
        if [ -n "${boot_once}" ]; then
          set prev_entry="${default}"
          save_env prev_entry
        fi
      fi
      save_env initrdfail
    fi; fi
function recordfail {
  set recordfail=1
  if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
set root='hd0,gpt4'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt4 --hint-efi=hd0,gpt4 --hint-baremetal=ahci0,gpt4  4ae1c922-c376-438c-b75e-85627897fede
else
  search --no-floppy --fs-uuid --set=root 4ae1c922-c376-438c-b75e-85627897fede
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_US
  insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
  set timeout=30
else
  if [ x$feature_timeout_style = xy ] ; then
    set timeout_style=hidden
    set timeout=3
  # Fallback hidden-timeout code in case the timeout_style feature is
  # unavailable.
  elif sleep --interruptible 3 ; then
    set timeout=0
  fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 60,59,55; then
  clear
fi
color_normal=light-gray/black
if [ -e ${prefix}/themes/ubuntu-mate/theme.txt ]; then
  insmod png
  theme=${prefix}/themes/ubuntu-mate/theme.txt
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
	set gfxpayload="${1}"
	if [ "${1}" = "keep" ]; then
		set vt_handoff=vt.handoff=7
	else
		set vt_handoff=
	fi
if [ "${recordfail}" != 1 ]; then
  if [ -e ${prefix}/gfxblacklist.txt ]; then
    if [ ${grub_platform} != pc ]; then
      set linux_gfx_mode=keep
    elif hwmatch ${prefix}/gfxblacklist.txt 3; then
      if [ ${match} = 0 ]; then
      else
        set linux_gfx_mode=text
      fi
    else
    fi
  else
  fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-4ae1c922-c376-438c-b75e-85627897fede' {
	recordfail
	load_video
	gfxmode $linux_gfx_mode
	insmod gzio
	if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt4'
	else
	fi
	linux	/boot/vmlinuz-6.11.0-26-generic root=UUID=4ae1c922-c376-438c-b75e-85627897fede ro  quiet splash $vt_handoff
	initrd	/boot/initrd.img-6.11.0-26-generic
submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-4ae1c922-c376-438c-b75e-85627897fede' {
	menuentry 'Ubuntu, with Linux 6.11.0-26-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.11.0-26-generic-advanced-4ae1c922-c376-438c-b75e-85627897fede' {
		recordfail
		load_video
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
		echo	'Loading Linux 6.11.0-26-generic ...'
		echo	'Loading initial ramdisk ...'
	menuentry 'Ubuntu, with Linux 6.11.0-26-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.11.0-26-generic-recovery-4ae1c922-c376-438c-b75e-85627897fede' {
		recordfail
		load_video
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
		linux	/boot/vmlinuz-6.11.0-26-generic root=UUID=4ae1c922-c376-438c-b75e-85627897fede ro recovery nomodeset dis_ucode_ldr
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/10_linux_zfs ###
### END /etc/grub.d/10_linux_zfs ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+x64.efi)" --class memtest $menuentry_id_option 'memtest86+' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt4'
	else
	fi
        linux    /boot/memtest86+x64.efi
menuentry 'Memory test (memtest86+x64.efi, serial console)' --class memtest $menuentry_id_option 'memtest86+-serial' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt4'
	else
	fi
        linux   /boot/memtest86+x64.efi console=ttyS0,115200
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/25_bli ###
if [ "$grub_platform" = "efi" ]; then
  insmod bli
fi
### END /etc/grub.d/25_bli ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Ubuntu 24.04.2 LTS (24.04) (on /dev/sda2)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-26c126a6-290a-4019-a32b-f6bb290663ea' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt2'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2  26c126a6-290a-4019-a32b-f6bb290663ea
	else
	  search --no-floppy --fs-uuid --set=root 26c126a6-290a-4019-a32b-f6bb290663ea
	fi
	linux /boot/vmlinuz-6.8.0-60-generic root=UUID=26c126a6-290a-4019-a32b-f6bb290663ea ro quiet splash $vt_handoff
	initrd /boot/initrd.img-6.8.0-60-generic
submenu 'Advanced options for Ubuntu 24.04.2 LTS (24.04) (on /dev/sda2)' $menuentry_id_option 'osprober-gnulinux-advanced-26c126a6-290a-4019-a32b-f6bb290663ea' {
	menuentry 'Ubuntu (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.8.0-60-generic--26c126a6-290a-4019-a32b-f6bb290663ea' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
	menuentry 'Ubuntu, with Linux 6.8.0-60-generic (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.8.0-60-generic--26c126a6-290a-4019-a32b-f6bb290663ea' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
	menuentry 'Ubuntu, with Linux 6.8.0-60-generic (recovery mode) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.8.0-60-generic-root=UUID=26c126a6-290a-4019-a32b-f6bb290663ea ro recovery nomodeset dis_ucode_ldr-26c126a6-290a-4019-a32b-f6bb290663ea' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-6.8.0-60-generic root=UUID=26c126a6-290a-4019-a32b-f6bb290663ea ro recovery nomodeset dis_ucode_ldr
	menuentry 'Ubuntu, with Linux 6.8.0-59-generic (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.8.0-59-generic--26c126a6-290a-4019-a32b-f6bb290663ea' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-6.8.0-59-generic root=UUID=26c126a6-290a-4019-a32b-f6bb290663ea ro quiet splash $vt_handoff
		initrd /boot/initrd.img-6.8.0-59-generic
	menuentry 'Ubuntu, with Linux 6.8.0-59-generic (recovery mode) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.8.0-59-generic-root=UUID=26c126a6-290a-4019-a32b-f6bb290663ea ro recovery nomodeset dis_ucode_ldr-26c126a6-290a-4019-a32b-f6bb290663ea' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-6.8.0-59-generic root=UUID=26c126a6-290a-4019-a32b-f6bb290663ea ro recovery nomodeset dis_ucode_ldr
	menuentry 'Memory test (memtest86+x64.bin) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/memtest86+x64.bin--26c126a6-290a-4019-a32b-f6bb290663ea' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/memtest86+x64.bin
	menuentry 'Memory test (memtest86+x64.bin, serial console) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/memtest86+x64.bin--26c126a6-290a-4019-a32b-f6bb290663ea' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/memtest86+x64.bin console=ttyS0,115200
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt6'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt6 --hint-efi=hd0,gpt6 --hint-baremetal=ahci0,gpt6  1f1ca355-c825-414f-98d0-09b81820edf4
	else
	  search --no-floppy --fs-uuid --set=root 1f1ca355-c825-414f-98d0-09b81820edf4
	fi
	linux /boot/vmlinuz-6.11.0-17-generic root=UUID=1f1ca355-c825-414f-98d0-09b81820edf4 ro quiet splash $vt_handoff
	initrd /boot/initrd.img-6.11.0-17-generic
submenu 'Advanced options for Ubuntu 24.04.2 LTS (24.04) (on /dev/sda6)' $menuentry_id_option 'osprober-gnulinux-advanced-1f1ca355-c825-414f-98d0-09b81820edf4' {
	menuentry 'Ubuntu (on /dev/sda6)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.11.0-17-generic--1f1ca355-c825-414f-98d0-09b81820edf4' {
		insmod part_gpt
		insmod ext2
Did you try the Boot-Repair-Disk?
I downloaded and installed it.
How do I put it on a pendrive?
Hi, @fixit7
You wrote:
Please, DON'T merge any partitions! At this time, there should be 2 priorities:
1 (Most important) - Preserve your data. This includes NOT doing any activities that may increase the risk of losing some / all of your data. Activities such as "merging" partitions and/or deleting partitions are definitely activities that may end up deleting data that you want to preserve!
2 (Second most important) - Get your system back to a bootable state.
It's not clear to me what "UM on my pen drive" means. Most people install Ubuntu MATE to an internal drive (e.g. an SSD or a HDD). It is possible to install Ubuntu MATE on a USB and run your desktop from there - this is typically called a persistent USB (e.g. How to Create Persistent Live USB of Ubuntu). Is this what you mean? Or are you running a "Live session" of the installer image (e.g. a USB created following the instructions at Preparing a USB Image | Ubuntu MATE or similar)?
Being able to use USB tethering is a feature that will (almost always) work "out of the box" in Ubuntu MATE. So if the phone has USB tethering enabled, and the cable works, it should be as easy as plugging everything in. I can imagine, however, that if you're using a persistent USB, that the issue could be more complicated because you may have changed network settings around.
I put Ubuntu Mate on a pen drive so I have a fallback in case I can not boot into UM.
I have everything repaired.
I had multiple partitions on my Western Drive 2 Tb.
My 2 Tb drive contains UM 24.02 and my Maxtor drive is a fat32.
I copy my backup files to it.
I could not get it on my pen drive and be able to boot to it to do the repair.
So - to be clear - you're running a persistent USB, and you are not able to connect via USB tethering to your phone.
When I plug in my phone via USB (in tethering mode), I can see that the USB connection is up via lsusb in the terminal, e.g.:
user@host:~$ lsusb
Bus 005 Device 023: ID 0123:4567 Samsung ... (tethering mode)
The network supplied by the connection can be seen via the ip command in the terminal, on my computer it'll be the last entry :
user@host:~$ ip link show
5: enx02468135: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
    link/ether 01:23:45:67:89:ab brd ff:ff:ff:ff:ff:ff
This is roughly what it looks like if everything is set up OK. So my first question would be - are you able to confirm that the USB connection has been established via lsusb, and then, is the network appearing in ip link show? If yes (to both) - then perhaps the DHCP client on your system is not configured correctly.
My tethering works great.
lsusb
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 004: ID 045e:076d Microsoft Corp. LifeCam HD-5000
Bus 003 Device 014: ID 04e8:6863 Samsung Electronics Co.,
Ltd Galaxy series, misc. (tethering mode)
ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
    link/ether 40:8d:5c:44:af:9b brd ff:ff:ff:ff:ff:ff
6: enx565fe565fdf0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
    link/ether 56:5f:e5:65:fd:f0 brd ff:ff:ff:ff:ff:ff
So the issue is resolved?
I recommend using balenaEtcher
