I have been experiencing some problems installing Ubuntu MATE on my Rasberry Pi.
When I run the installation process, the resoloution is completeley wrong for my monitor, making it very frustrating to use, as everything is so big. Please help!
Welcome @squid422, this is where you want to be (below) .
https://ubuntu-mate.community/c/general-discussion/raspberry-pi-2
Someone will help you shortly.
Welcome to the community @squid422! I moved the thread to the Raspberry Pi subcategory so we do not confuse this with the desktop edition.
We could do with a few more details to help identify why this is happening.
- Are you connected via HDMI or the yellow connector (forgot the name)?
- Is this a TV or monitor?
- Do you know the maximum supported resolution (eg. 1920x1080) of your screen and a rough idea of which size you currently see (eg. 640x480)?
Linux distributions in general are usually quite good at determining the best resolution for the screen, you could try a different monitor to be sure there is not a fault with the Raspberry Pi. Once installation is complete, you can manually set a resolution in System → Preferences → Hardware → Monitors.
Another answer that may help on a different thread:
