Hi Team,
I recently updated my distro from 18.04 LTS to 20.04 and used it without any issues for about 1 week. I did not used my desktop after that.
But, due to some work I again wanted to use my dear desktop, but now it is suddenly is not booting up.
I am just seeing a black blinking screen with a cursor after the MATE loading screen.
Here, is the error screen attached. It is stuck at the login screen I assume.
I also entered the safe mode and run the repair broken packages option as well. But no luck.
Kindly advise on this as I do not want to do the formatting and re-installing the OS.
Kind Regards,
Santosh E.
