Hi! When i wanna use the Ubuntu Mate Software Boutique, the icons and text not appear, just a left part of the window’s program can see. I upped an image to show.
open Control Centre > Hardware > Additional Drivers and look for the latest Nvidia driver as you have an GeForce GPU and there may be drivers available for it, select the tested ones!!:
Yeah but nothing! I tried install NVIDIA-Linux-X86-173.14.39-pkg1.run (http://nvidia.com/object/unix.html) after stop the service by lightdm and nothing again. I'd give up.. .
if you want to install the Intel microcode package manually, use the following terminal command (USE AT YOUR OWN RISK!):
sudo apt install intel-microcode
This may or may not help you?.
Another alternative is to install the following modprobe package for Nvidia, again; it may or may not help you?:
sudo apt install nvidia-modprobe
“This setuid program is used to create NVIDIA Linux device files and load the NVIDIA kernel module, on behalf of NVIDIA Linux driver components which may not have sufficient privileges to perform these actions on their own.”
If you have a problem with either of the above commands, boot into recovery mode (see Update guide above) and run the following command:
sudo apt remove nvidia-modprobe
and/or:
sudo apt remove intel-microcode
Restart your PC with Ctrl + Alt + Del!. DO NOT CLICK ON RESUME!.
Hi Wolfman!
I tried change the video resolution to 800x640 and works apt mate welcome, but de boutique not.
I’ll try your sugestion and return after with the result.
