Looking at the trailer, Ubuntu MATE looks very promising. I would like to switch from Ubuntu (Unity)
But I remembered that I used Linux Mint not long ago, and it didn’t work with the Arc theme.
I love Arc.
Arc is love.
Arc is life.
And I don’t want to install MATE and then see that it’s not compatible.
In short: does the Arc theme work for you in MATE?
After playing with this theme in Solus, I would be interested in knowing myself…
Just installed both themes in 16.10 and seem to work just fine. Running arc-dark at the moment and kinda like it
Anyhow, thats the result of my 2 minute test.
Arc works awesome with mate
. I too am a huge fan of arc…
You can without doubt use it with Umate.
Just tried, works fine ! no problem ...
Hi, I'm a new member here. I'm using the X-Arc theme. Everything quite works out, but in some cases, like in VLC player, it's not working as expected.
Has this happened to someone else? Is there a fix or workaround?
Thanks in advance...
