Ubuntu17.10 install problem
I choose the first option when I choose install type
upgrade ubuntu16.04.3 LTS to ubuntu MATE 17.10
an error come out:
The partition table format in use on your dists normally requires you to create a separate partition for boot loader code. This partition should be marked for use an “EFI boot partition” and should be at least 35MB in size.Note that this is not the same as a partition mounted on /boot.
if you do not go back to the partitioning menu and correct this error, boot loader installation may fail later, although it may still be possible to install the boot loader to a partition.
I push continue, and my installation fail for that…
Sounds like the upgrade installer was trying to install for UEFI booting, which needs a ESP partition. Do you know if your 16.04.3 installation was installed for BIOS booting?
