Is it possible to use ultracopier (http://ultracopier.first-world.info/) with caja ? I installed it but I can’t make it worked.
Hi Jack,
try downloading the deb package for U14.10 from here (might not work if you are using UM 15.04!?):
http://pkgs.org/search/ultracopier
You might want to remove the other one first!.
Thanks for answering. I tested this solution but it doesn’t work. It is the same version which are in the ubuntu 15.04 repository.
Hi Jack,
is your software sources download location set to “Main”?, try changing the “Download from” setting as that might help!:
