klein
12 October 2018 12:34
1
good day
um 16.04 64bit
i was trying out vertialbox and it installed:
grub menu :
4.8.0-53-lowlatency
4.8.0-53-lowlatency (upstart)
4.8.0-53-lowlatency (recovery mode)
4.4.0-137-generic
4.4.0-137-generic (upstart)
4.4.0-137-generic (recovery mode)
i would like to uninstall :
4.8.0-53-lowlatency
and go back to :
4.4.0-137-generic
4.8.0-53-lowlatency does not boot , but 4.4.0-137-generic will boot.
how do i uninstall 4.8.0-53-lowlatency kernel safely ?
dpkg -l | grep linux-image to get a list of the kernels installed.
then
sudo dpkg --purge linux-image-4.8.0-53 (the exact name of the kernel to remove)
klein
12 October 2018 15:12
3
dpkg: warning: ignoring request to remove linux-image-4.8.0-53 which isn't installed
it is showing up in grub menu but it isn't installed ?
ii linux-image-4.8.0-53-lowlatency:i386 4.8.0-53.56~16.04.1 i386 Linux kernel image for version 4.8.0 on 32 bit x86 SMP
klein
12 October 2018 15:27
4
pavlos_kairis this seemed to work though
open synaptic
search for linux-image
linux-image-4.8.0-53 completely remove ,purge
sudo update-grub
thanks pavlos_kairis
