I've recently installed UM 17.04, and i'm unable to launch caja to open files in the terminal window. for example, in the terminal:
> caja somerandom.pdf
I used to run UM 16.04 LTS, and I used to be able to open all sorts of different files automatically from the terminal by using the caja command but instead now I get a pop error message saying:
'Could not display "/home/someone/somerandom.pdf"
The location is not a folder.'
Is this feature disabled in 17.04? Or is there a setting that I can check to make this work again?
Well basicly this won't work since caja is a file browser and knows how to open only directories .
in order to open a file from terminal you have to specify the program and file in terminal like so
atril somerandom.pdf
or use xdg-open to open the prefered application like @Meticulus said .
