I use a USB Audio Device with an Intel NUC. When you reboot, Alsamixer & the Control Center Sound
revert to HDMI which I quess is the system default. How can I make my settings the default?
I don’t see Sound Settings > Hardware. All I have in my UM16.04 is The Control Center ‘Sound’ which is different from what you posted. The CC ‘Sound’ has a USB Audio Device that says Analog Stereo Output! Every time I shut down or reboot, Alsamixer & ‘Sound’ revert back to HDMI. I want to make the USB Audio Device the default.
are you using Raspi?.
try the following terminal command:
sudo add-apt-repository ppa:ubuntu-audio-dev/alsa-daily && sudo apt-get update && sudo apt-get install oem-audio-hda-daily-dkms
@wizd3m, thanks for the heads up, I wasn’t paying attention to that part!.
I got the info from here and I hope it helps!:
