Unable to print
Hello,
To start, I can ping my printers IP, however, when I go to connect to my HP OfficeJet_Pro_7740, I’m presented with “org.cups.cupsd.service” is not running.
When I run
systemctl status org.cups.cupsd.service
Unit org.cups.cupsd.service could not be found.
The cups.service was inactive and masked. I unmasked it and started it, no change.
This seems to have stopped with the last upgrade. Version is Ubuntu 24.04.3 LTS.
I didn’t find anything org.cups.cupsd.service in Help and Support.
What am I missing?
Thanks for any suggestions.
Subrag
What is reported when you enter
lpstat -t
Also, what do you see when you enter the following in the address line of a browser:
http://localhost:631/printers/
when I run lpstat -t
scheduler is not running
and unable to connect for the browser address.
Let's start with the most basic.
Plug in your printer and power it up (not sure, but hoping for auto-detect for the following step).
Try installing/repairing the CUPS installation:
sudo apt-get install --reinstall cups
After that, try the following again to see if you have any Printers showing:
If no printers are showing, then you will need to use the OS built-in "service" for defining/configuring printers.
system-config-printer
You may also want to browse thru the following discussions to see what insights/tools you might discover which could be useful for your context:
As it turns out, re-installing cups got printing working again but it seems like there is functionality that is missing. When I go to
http://localhost:631/printers/  it shows the  printer as being HP-Officejet-Pro-7740-Wide-Format-All-in-one.  When I look that up that printer it says that its not supported any more.  What drivers should I use now?
 Thanks
That printer uses
Apparently, "HPLIP" is required to service devices using "HP PCL 3 Enhanced".
Depending on the situation (your abilities), you might want to consider this, directly from the "source", as a first try:
If that doesn't work, you can then attempt the following sequence:
sudo apt install hplip
sudo apt install hplip-gui
If those don't work, some digging around came up with the following:
which points to this:
I have no idea if that will work, but the claim is that it does.
Note that it is a SNAP package.
If anyone knows anything better for this situation, please share your insights/wisdom.
