Hi guys,
I’m not able to see any kind of DVD Disk; I have used VLC, Totem, the error is ( in Italian )
“Impossibile leggere il filmato” >> “Unable to read the film”
I have installed all the libraries, but no way; I 've tried with different DVD, same result.
Can you help me?
I’m using ubuntu Mate 17.04
Thanks in advance
Which libraries have you installed?
Have you issued these commands?
sudo apt-get install libdvd-pkg
sudo dpkg-reconfigure libdvd-pkg
Good luck gianlucaf.
Hallo gianlucaf
You could try this:
Go to: Welcome > Getting started > Updates and Extras
Once there select the following for installation:
and
- Blue-ray and DVD Playback Support
To be absolutely sure that these new packages will be working, re-boot your computer.
Now try to look at your DVD.
Did that help?
Hi guys,
I have installed “Blue-ray and DVD Playback Support” and it works well!
Thanks to the community!
