Unresponsive Pictures copy from Android
Copying large amounts of pictures from android phone to PC it takes large amount of time to respond to commands, or even copy, if Caja will not crash.
I observe this behavior from Mate 20.04 and same in 22.04...is related to Ubuntu, to phone, or both?
Does anyone know a fix for this?
I think I have to search on something over internet or just remove SD and do it on PC
Ok, so no one has this issue , I remember just one complain in the past on internet for this issue.
Probably no one is using anymore USB cables to transfer Pictures from Phone to PC... or maybe people does not use anymore PCs this days, Phones are enough.
I search on internet for fix, nothing, nothing worked. So I switch to a different approach, by ditching the entire USB MTP transfer,
And idea it works marvelous... of course I lose some picture in the process using an automatic file synchronization tool set it wrongly as classical for linux apps lacking good documentation for use and configure,
Also test ssh android server and also this is quite good
i just have to search for an on demand file synchronization tool if exist or even a linux network share mount without any success finding one of those in the past...
