Is there a problem lately with the update center? I cannot run any updates since yesterday no matter which server I choose (main or local) and my internet connection works fine. Should I change my repository configuration?
p.s. wrong thread post!
Hi! I have the same issue. After recent update to 16.04.3 updating does not work. Error messages says cannot connect to servers.
After sudo apt update by terminal the problem seems to be google chrome
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://dl.google.com/linux/chrome/deb stable Release:
Any thoughts? I run mate 16.04.3 .
I run by terminal:
wget -q -O - https://dl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
and it worked.
That worked for me too. Thanks !
