Update seems to have broken my top panel
Hi all just did an update to 14.04 using Compiz about 12 hours ago which included QT4 updates and I noticed some of my notification icons namely Network, volume and laptop battery status are no just empty black spaces. I run a Lenovo t61p with Nvidia card and drivers, has anyone else experienced this ?
Have you tried to remove everything from the right hand side of the panel and then going to the panel and right clicking and choosing “add to panel…”, then reinstating the various system icons?
I updated Qt yesterday and nothing broke thankfully. That said, I use the indicator version and not the standard MATE ones.
You could try resetting the panel, by opening Ubuntu MATE Tweak and changing the panel layout.
Now, why didn’t I think of that…
