Howdy. I updated my nvidia-settings configuration to fix the screen tearing issue when playing video games. But I must have messed something up, because now after I've rebooted, I can't log in.
The login screen shows up, but once I put in my password, the screen blanks, flickers, then after a few seconds comes back to the login screen.
I created another user to confirm it's not user settings. Same result.
If I purge the nvidia drivers and use nouveau, everything works fine. It's just not optimal for gaming.
Looking at /var/log/Xorg.0.log, it segfaults for some reason. The first four lines here repeat a bunch, then the segfault. Other than this, I don't have much to go on.
[ 93.105] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 93.105] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 93.105] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 93.337] (EE)
[ 93.337] (EE) Backtrace:
[ 93.338] (EE) 0: /usr/lib/xorg/Xorg (OsLookupColor+0x13c) [0x55cb53be1aec]
[ 93.338] (EE) 1: /lib/x86_64-linux-gnu/libpthread.so.0 (funlockfile+0x60) [0x7fa922ef23c0]
[ 93.338] (EE) 2: ? (?+0x0) [0x0]
[ 93.338] (EE)
[ 93.338] (EE) Segmentation fault at address 0x0
[ 93.338] (EE)
Fatal server error:
[ 93.338] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 93.338] (EE)
[ 93.338] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 93.338] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 93.338] (EE)
[ 93.353] (EE) Server terminated with error (1). Closing log file.
I also think it's pretty dumb that it says to look at /var/log/Xorg.0.log, but this is /var/log/Xorg.0.log.
