So I thought I would try to upgrade vice fresh install on my Dell laptop. Hitting the upgrade button does nothing but close the updater window. I would have thought it would have started the upgrade process.
Hi mate
Can you please try opening a terminal and execute :
sudo apt update
sudo apt upgrade
This will fully update your computer.
Thanks. I will do that. I was thinking the developers would want to know of the challenges some of us experienced.
Is there a difference between
sudo do-release-upgrade
and
sudo apt upgrade
I only ask after reading this
do-release-upgrade will upgrade your OS to new version ex :
You are running Ubuntu Mate 19.10. This command will upgrade Ubuntu Mate to 20.04.
apt update - will refresh apt cache - check for packages versions, and analyse with ones on your PC can be upgraded.
apt upgrade - will do the work that apt update have prepared
will upgrade all packages on your computer that have a new version.
Thanks. I see I was not clear in my original post. I currently have 18.04 and want to upgrade to 20.04.
I don't want to go to 20.10, just stick with LTS. So would
take me to 20.10 or 20.04?
OK, I found the issue. I installed Wine long ago. About a year or so ago it stopped updating because of incompatible packages. So even the terminal command would not upgrade the OS, but it at least provided a message to lead me to the cause. I removed Wine then the Upgrade button then worked.
Now I wish I did a fresh install as it has been 3 hours and the upgrade process is still chugging along. A fresh install would have been completed long ago.
Update: Upgrade completed in 8 hours. Everything looks good so far.
