how can I upgrade? the software upgrader does not offer the upgrade even though I have checked upgrade to LTS should be offered. it upgrades the kernel and the linux image, but the desktop stays the same.
stephen@stephen-AO725:~$ uname -a
Linux stephen-AO725 4.4.0-57-generic #78~14.04.1-Ubuntu SMP Sat Dec 10 00:14:47 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Hi @stephenbbb,
take a look here:
Please verify its 14.04:
lsb_release -a
No LSB modules are available.
Release: 14.04
Codename: trusty
Hi @stephenbbb,
take a look here:
Did you run the following terminal (Ctrl + Alt +t) command as well?:
sudo update-manager -d
First, make sure that your packages are up to date:
sudo apt-get update && sudo apt-get dist-upgrade
Then, try to start the Update Manager like this and check if it tells you that there’s an upgrade available to Ubuntu 16.04:
update-manager -d
