USB External Hard Drive Enclosure are not allowing permission on shared folder
I m not able to access a shared folder over the network using samba/SMB.
I have no problems accessing the shared folder that is in original installation (download folder).
I added an USB 2.0 External Hard Drive Enclosure USB extension. No problems adding data to the Hard drives yet I m not able to allocate permission to be view over the network as a shared resource. I can see the shared folder over the network. When I tried to accessed it is when it says there are no permissions.
This is happens only with the shared folders in the enclosure not the folders in the installation.
Thank you
pydf
Filesystem Size Used Avail Use% Mounted on
/dev/sda5 915G 40G 829G 4.3 [.....] /
/dev/sda1 511M 4096B 511M 0.0 [.....] /boot/efi
/dev/sdc1 916G 58G 811G 6.4 [.....] /media/chello/205f~a5f2-07b48d8e6f82
/dev/sdb1 5589G 930G 4659G 16.6 [#....] /media/chello/Data
/dev/loop2 55M 55M 0 100.0 [#####] /snap/core18/1885
/dev/loop0 55M 55M 0 100.0 [#####] /snap/core18/1932
/dev/loop1 31M 31M 0 100.0 [#####] /snap/snapd/10238
/dev/loop7 31M 31M 0 100.0 [#####] /snap/snapd/10492
/dev/loop4 128k 128k 0 100.0 [#####] /snap/software-boutique/54
/dev/loop6 15M 15M 0 100.0 [#####] /snap/ubuntu-mate-welcome/571
/dev/loop5 15M 15M 0 100.0 [#####] /snap/ubuntu-mate-welcome/575
Thank you
