Hey All,
my Samsung 1640 ML shows up automatically under Lubuntu 15.04 and 15.10 but not under Ubuntu Mate 15.10 nor 16.04.
When I reuse Lubuntu the printer still gets recognised again.
Any idea why Ubuntu Mate doesn’t show the USB printer ?
When clicking Add under Printers a wheel is spinning and only LPT #1 and Serial Port #1 appear.
do you have a USB cable attached to the printer or are you trying to to do it wire-less?.
Hello,
I am using a USB cable. Actually I used a few different ones so I could be certain the problem has nothing to do with the cable.
Have you checked the Samsung support pages for Linux drivers?:
http://www.samsung.com/uk/support/category/pcperipheralsprinter/printer/
Hello,
I was already at this URL and saw only drivers for Windows/Mac.
Furthermore I like to point to the fact that with other Linuxes all works.
It must have something to do with these Ubuntu releases.
Anyway thanks for your input.
I have no idea if these will work as some are old links, it might give you and idea or two!: ![]()
http://www.bchemnet.com/suldr/
I hope it helps!. ![]()
Hello Wolfman,
following your clues I downloaded the appropriate driver and the ML-1640 got recognised…but now Ubuntu Mate 16.04 continuously disables the printer. In other words under properties I can check ( enable ) but again and again Ubuntu Mate 16.04 turns it back off.
Any idea on this ?
regards.
Hi @meandyesi,
I don't really know as I don't have a Samsung printer?, are you using a guest account?, have you done a full system update?:
