I am temporarily living in my car.
Is there a way to install it on Samsung a25 fone?
I want to still practice using it.
If you want to install UbuntuMATE on a Samsung Galaxy A25 phone, the first big issue is whether you can do what is called "rooting" the device, namely being able to get access to all of the installed OS with root-level access.
If you can achieve that successfully, then its a matter of verifying whether there is such a thing as trying a "Live UM" on the phone, before installing something like VMware to run UM.
Or you can research to determine if your phone is compatible with UbuntuTOUCH.
After all, it is my understanding that UbuntuMATE is intended as a Desktop environment, not specifically designed for a telephone, although many components are "mobile-ready".
Also wondering, given your situation, whether
you are considering using the phone as only a network access-point gateway for your computer, or
you are looking to limit all your Linux usage to the A25's GUI?
My desktop system is safely at my oldest daughters house.
So when my homelessness ends, I "will be cooking again" with U.M.
Rooting a phone can result in a non-functional fone. I.E. an expensive paper weight.
This is pretty handy device. It can charge my phone, and anything up to 400 watts.
So it will run many 120 volt A.C. devices
Like my shaver and charging my shaver.
The orange device is a diffuser. I use lavender for the oil.
I didn't know what your level of knowledge on that was. I was putting that out there as something that many have pursued and found to be beneficial. But of course, one must always research to ensure that such approaches fit one's own hardware/software context.
Have you looked for any Linux emulator Apps in the Google Android store? I haven't had a device for at least 3 years, so haven't checked myself.
This might be possible; but Ubuntu MATE is a desktop operating system, and so the chances of it being clean and functional on a phone are (practically) zero.
Ubuntu Touch, Mobian, postmarketOS, all look like more promising options as operating systems.
I believe it will be possible. Assuming we're talking of keeping the phone's OS (Android) and using an application to enable access to a local Linux instance running on the device. At minimum, it will have terminal output, but it supports a display too.
It's called AnLinux and needs the Termux app. I tried playing with it before, but I can't remember much. It doesn't require root since it uses PRoot, which allows isolated containers/chroots without needing root's permission.
You'll probably need plenty of storage space and a good internet connection.
On my very old rooted phone, I once had a Linux running in the background, and could use X2GO to remotely connect (SSH) into it from the desktop with the MATE environment. ![]()
Handy yes but power inverters really only work if the vehicle is running and a running vehicle uses gas and in a stationary vehicle that's not the safest thing to do,CO is kinda deadly.
Not true my friend That is not true.
If you're using a power inverter and the engine isn't running you'll drain your battery and then oops no starting for you without a jump.And CO is definitely deadly.
I have a unit with similar specs as this one.
I can charge my phone, charger for my hearing aid, and my rechargeable razor at the same time.
I then turn on my car for a minute. Cold cranking amps are around 550 amps for my car battery.
Outta here.
I guess the past 30 years working on cars was just a waste of my time.I'll leave it to the expert then.
I do not understand your response.
