I wish to maintain multiple ssh terminal to 7 lan servers, using a unique color for each terminal window. I have been doing this with the terminal gui, but I would like to be able to use gsettings to edit profiles from a script. My problem is that I can’t seem to construct a gsettings get/set command that works. I can see that, under org.mate.terminal.profiles, there is a list of profiles, starting with ‘default’, with additional profiles listed below as Profile0 to ProfileNN. Can someone show me the proper syntax to fetch the ‘login-key’ from the default profile, and then set it?
I am using:
Ubuntu Release 16.04.1 LTS (Xenial Xerus) 64-bit, with MATE 1.12.1
