Using ORBI wifi
Hi
I run UbuntuMate on a Raspberry Pi 3+. I have an ORBI mesh wifi network.
What I have noticed is that the Pi makes a connection with a single satellite. When I look at the wifi status I can see multiple access point (from each satellite and the hub).
Is t possible to set it up so it sees the mesh as a single access point as it does on Windows or the Mac.
Cheers
Rishi
