Using RPi 3B+ without success
I have received a Raspberry Pi 3 model B+ and I'm starting to setup it up. I'm using the 32GB MacroSC card, that I formatted using the SD Card Formatter. I then downloaded and installed, using the Raspberry Pi Imager, "ubuntu_mate-22.04.desktop-arm64+raspi,img.xz type XZ file". I think I have the program up and running, but it takes about 30 to 40 seconds after clicking on an ICON, for the ICON to open.
Is this normal or have I downloaded and installed the wrong version of ubuntu mate? Should the RPi 3 operate this slowly? Just learning how to use the RPi 3, so I have a lot to learn yet.
Welcome, @Goldie to the community!
Have you tried the 32 bit version? I only have experience with the RPi 4 with 4 GB ram and it was the best compared with Ubuntu and Raspberry native OS.
Another choice is to forego U-Mate and stick with R-Pi Native OS due to the low ram requirement.
Best of luck.
Thank you Patreon - I think that 32 bit OS seems to be working now. If you don't mind another question, If I go to add/delete software and click on an item, where does it go?
Still learning.
If you're referring to the software boutique it gets queued up and then you click on the number in the upper right hand corner to install. I would show you a screenshot but I'm on 24.04 and there is no software boutique anymore.
Alternatively, sudo apt install works on RPi OS as well as U-Mate.
Best of luck.
