/usr/bin/ld: warning: libcrypto.so.1.0.0, needed by /usr/local/lib/libcurl.so, may conflict with libcrypto.so.1.1
Hi!
Need help for that here to fix:
Can I remove package "libssl1.0.0" from my system without problems if package "libssl1.1" is installed?
Which packages of "libcurl" do I need?
Installed packages of libcurl:
libcurl3-gnutls
libcurl4
libcurlpp-dev
libcurlpp0
Which of these packages can I remove without problems to fix that
conflict?
Usually such libraries should be installed using apt.
So you have to open terminal and type:
sudo rm /usr/local/lib/libcurl.so*
sudo apt-get install --reinstall libssl-dev  libcurl4-openssl-dev
ok, thanks @ Norbert_X
