Var/tmp folder is filled very fast
Hallo folks
I’ve got an issue with my var/tmp/ folder. This folder get datas very fast. More or less 5 Gb in one Day. I had to delete the content manually to make regular udates of Ubuntu Mate, because /directory was full.
Is there a workaround to fix it?
Thanks and best wishes
Atreju
Hey, Atreju. It’s hard to say what may be causing that folder to fill up so quickly without looking at it. Try outputting that directory with the ls -l command. This would give you a better idea of what those files are and where it is coming from. Hope this helps.
Here seems to be a similar problem and I’m sure, it’s a problem with Canon printing drivers:
https://answers.launchpad.net/ubuntu/+question/400340
