Philippe:
dmesg
[ 0.467857] platform eisa.0: EISA: Detected 0 cards
[ 0.467862] intel_pstate: Intel P-state driver initializing
[ 0.468071] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.468138] drop_monitor: Initializing network drop monitor service
[ 0.468312] NET: Registered protocol family 10
[ 0.478267] Segment Routing with IPv6
[ 0.478296] NET: Registered protocol family 17
[ 0.478342] Key type dns_resolver registered
[ 0.478701] RAS: Correctable Errors collector initialized.
[ 0.478737] microcode: sig=0x206a7, pf=0x10, revision=0x2f
[ 0.478783] microcode: Microcode Update Driver: v2.2.
[ 0.478788] IPI shorthand broadcast: enabled
[ 0.478795] sched_clock: Marking stable (478554656, 224519)->(482550424, -3771249)
[ 0.478876] registered taskstats version 1
[ 0.478885] Loading compiled-in X.509 certificates
[ 0.481414] Loaded X.509 cert 'Build time autogenerated kernel key: 9e1aeb581c5145b0cc48f50fdf6e09edec23120f'
[ 0.481452] zswap: loaded using pool lzo/zbud
[ 0.481567] Key type ._fscrypt registered
[ 0.481569] Key type .fscrypt registered
[ 0.491128] Key type big_key registered
[ 0.495633] Key type encrypted registered
[ 0.495638] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.495645] ima: No TPM chip found, activating TPM-bypass!
[ 0.495652] ima: Allocated hash algorithm: sha1
[ 0.495660] ima: No architecture policies found
[ 0.495667] evm: Initialising EVM extended attributes:
[ 0.495668] evm: security.selinux
[ 0.495669] evm: security.SMACK64
[ 0.495669] evm: security.SMACK64EXEC
[ 0.495670] evm: security.SMACK64TRANSMUTE
[ 0.495670] evm: security.SMACK64MMAP
[ 0.495671] evm: security.apparmor
[ 0.495671] evm: security.ima
[ 0.495672] evm: security.capability
[ 0.495673] evm: HMAC attrs: 0x1
[ 0.496079] PM: Magic number: 0:968:166
[ 0.496207] rtc_cmos 00:01: setting system clock to 2020-08-08T07:11:16 UTC (1596870676)
[ 0.497619] Freeing unused decrypted memory: 2040K
[ 0.498100] Freeing unused kernel image memory: 2712K
[ 0.501575] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.534534] Write protecting the kernel read-only data: 22528k
[ 0.535098] Freeing unused kernel image memory: 2008K
[ 0.535390] Freeing unused kernel image memory: 1192K
[ 0.547375] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.547377] x86/mm: Checking user space page tables
[ 0.559122] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.559125] Run /init as init process
[ 0.714899] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20190816/utaddress-204)
[ 0.714908] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.714912] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 0.714918] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.714919] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 0.714924] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.714926] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 0.714931] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.714932] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 0.717204] ahci 0000:00:1f.2: version 3.0
[ 0.717774] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.719251] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 0.722418] cryptd: max_cpu_qlen set to 1000
[ 0.726099] libphy: r8169: probed
[ 0.726591] r8169 0000:02:00.0 eth0: RTL8168evl/8111evl, 24:f5:aa:c4:cc:2f, XID 2c9, IRQ 27
[ 0.726594] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.730391] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x5 impl SATA mode
[ 0.730396] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 0.743636] scsi host0: ahci
[ 0.743896] scsi host1: ahci
[ 0.744032] scsi host2: ahci
[ 0.744346] scsi host3: ahci
[ 0.746755] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 0.747325] scsi host4: ahci
[ 0.747464] scsi host5: ahci
[ 0.747524] ata1: SATA max UDMA/133 abar m2048@0xf0708000 port 0xf0708100 irq 26
[ 0.747525] ata2: DUMMY
[ 0.747528] ata3: SATA max UDMA/133 abar m2048@0xf0708000 port 0xf0708200 irq 26
[ 0.747529] ata4: DUMMY
[ 0.747529] ata5: DUMMY
[ 0.747530] ata6: DUMMY
[ 0.782364] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.802406] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.813620] checking generic (e0000000 410000) vs hw (e0000000 10000000)
[ 0.813622] fb0: switching to inteldrmfb from VESA VGA
[ 0.813695] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 0.822470] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.822474] [drm] Driver supports precise vblank timestamp query.
[ 0.827526] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 0.913454] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[ 0.914596] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 0.914937] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[ 0.938834] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.938836] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.939130] hub 1-1:1.0: USB hub found
[ 0.939206] hub 1-1:1.0: 6 ports detected
[ 0.950565] fbcon: i915drmfb (fb0) is primary device
[ 0.950567] fbcon: Deferring console take-over
[ 0.950571] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 0.959223] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.959225] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.959503] hub 2-1:1.0: USB hub found
[ 0.959585] hub 2-1:1.0: 6 ports detected
[ 1.062426] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.064602] ata3.00: ATAPI: TSSTcorp CDDVDW SN-208BB, SC00, max UDMA/100
[ 1.066401] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.067411] ata3.00: configured for UDMA/100
[ 1.072656] ata1.00: ATA-8: ST500LM012 HN-M500MBB, 2AR10002, max UDMA/133
[ 1.072662] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.079034] ata1.00: configured for UDMA/133
[ 1.079357] scsi 0:0:0:0: Direct-Access ATA ST500LM012 HN-M5 0002 PQ: 0 ANSI: 5
[ 1.079705] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.079774] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 1.079775] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.079793] sd 0:0:0:0: [sda] Write Protect is off
[ 1.079795] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.079836] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.082332] scsi 2:0:0:0: CD-ROM TSSTcorp CDDVDW SN-208BB SC00 PQ: 0 ANSI: 5
[ 1.135212] sda: sda1
[ 1.136010] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.172491] sr 2:0:0:0: [sr0] scsi3-mmc drive: 16x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.172493] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.186870] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 1.186976] sr 2:0:0:0: Attached scsi generic sg1 type 5
[ 1.230437] usb 1-1.4: new high-speed USB device number 3 using ehci-pci
[ 1.246452] usb 2-1.1: new full-speed USB device number 3 using ehci-pci
[ 1.318111] random: fast init done
[ 1.335178] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.335195] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.335204] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.357695] usb 1-1.4: New USB device found, idVendor=0ac8, idProduct=c349, bcdDevice= 0.15
[ 1.357699] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.357701] usb 1-1.4: Product: WebCam SC-03FFL11739P
[ 1.357703] usb 1-1.4: Manufacturer: Vimicro Corp.
[ 1.357785] usb 2-1.1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 1.357787] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.357788] usb 2-1.1: Product: USB Receiver
[ 1.357789] usb 2-1.1: Manufacturer: Logitech
[ 1.363407] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.368826] usbcore: registered new interface driver usbhid
[ 1.368827] usbhid: USB HID core driver
[ 1.371909] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C534.0001/input/input7
[ 1.406415] tsc: Refined TSC clocksource calibration: 2394.559 MHz
[ 1.406435] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2284235ba97, max_idle_ns: 440795203400 ns
[ 1.406536] clocksource: Switched to clocksource tsc
[ 1.430781] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input0
[ 1.431084] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/input/input8
[ 1.431269] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/input/input9
[ 1.438454] usb 2-1.4: new full-speed USB device number 4 using ehci-pci
[ 1.490645] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/input/input10
[ 1.490873] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input1
[ 1.548827] usb 2-1.4: New USB device found, idVendor=0cf3, idProduct=3004, bcdDevice= 0.01
[ 1.548835] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.548839] usb 2-1.4: Product: Bluetooth USB Host Controller
[ 1.548842] usb 2-1.4: Manufacturer: Atheros Communications
[ 1.548846] usb 2-1.4: SerialNumber: Alaska Day 2006
[ 1.550787] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input0
[ 1.611400] psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x350f00)
[ 1.626740] psmouse serio1: elantech: Synaptics capabilities query result 0x08, 0x17, 0x0c.
[ 1.642511] psmouse serio1: elantech: Elan sample query result 01, 22, 85
[ 1.720953] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input5
[ 1.723082] logitech-djreceiver 0003:046D:C534.0002: hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input1
[ 1.785156] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
[ 1.785826] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input13
[ 1.785967] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input14
[ 1.786062] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input15
[ 1.786159] hid-generic 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:1d.0-1.1/input1:1
[ 1.787155] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
[ 1.787543] input: Logitech Wireless Mouse PID:4054 Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input20
[ 1.787656] hid-generic 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4054] on usb-0000:00:1d.0-1.1/input1:2
[ 1.913501] input: Logitech Wireless Keyboard PID:4023 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input24
[ 1.913682] logitech-hidpp-device 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:1d.0-1.1/input1:1
[ 1.953387] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input25
[ 1.953621] logitech-hidpp-device 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:1d.0-1.1/input1:2
[ 2.474258] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.773360] random: crng init done
[ 4.773368] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.242387] systemd[1]: Inserted module 'autofs4'
[ 5.520376] systemd[1]: systemd 245.4-4ubuntu3.2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 5.538590] systemd[1]: Detected architecture x86-64.
[ 5.582077] systemd[1]: Set hostname to <saptarshi-300E4C-300E5C-300E7C>.
[ 8.576272] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[ 9.385330] systemd[1]: Created slice system-modprobe.slice.
[ 9.385598] systemd[1]: Created slice User and Session Slice.
[ 9.385679] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.385941] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.385984] systemd[1]: Reached target User and Group Name Lookups.
[ 9.385997] systemd[1]: Reached target Remote File Systems.
[ 9.386012] systemd[1]: Reached target Slices.
[ 9.386177] systemd[1]: Listening on Syslog Socket.
[ 9.386282] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.386362] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.386591] systemd[1]: Listening on Journal Audit Socket.
[ 9.386691] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.386820] systemd[1]: Listening on Journal Socket.
[ 9.386938] systemd[1]: Listening on udev Control Socket.
[ 9.387027] systemd[1]: Listening on udev Kernel Socket.
[ 9.388072] systemd[1]: Mounting Huge Pages File System...
[ 9.389244] systemd[1]: Mounting POSIX Message Queue File System...
[ 9.390861] systemd[1]: Mounting Kernel Debug File System...
[ 9.392021] systemd[1]: Mounting Kernel Trace File System...
[ 9.394046] systemd[1]: Starting Journal Service...
[ 9.395669] systemd[1]: Starting Set the console keyboard layout...
[ 9.396982] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 9.397084] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 9.446267] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.446323] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.492205] systemd[1]: Starting Load Kernel Modules...
[ 9.493214] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 9.494715] systemd[1]: Starting udev Coldplug all Devices...
[ 9.496133] systemd[1]: Starting Uncomplicated firewall...
[ 9.498506] systemd[1]: Mounted Huge Pages File System.
[ 9.498764] systemd[1]: Mounted POSIX Message Queue File System.
[ 9.498981] systemd[1]: Mounted Kernel Debug File System.
[ 9.499200] systemd[1]: Mounted Kernel Trace File System.
[ 9.505932] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 9.691432] systemd[1]: Started Journal Service.
[ 9.940351] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 10.201806] systemd-journald[375]: Received client request to flush runtime journal.
[ 10.698426] Adding 2097148k swap on /swapfile. Priority:-2 extents:6 across:2260988k FS
[ 11.065883] lp: driver loaded but no devices found
[ 11.268354] ppdev: user-space parallel port driver
[ 11.368360] bpfilter: Loaded bpfilter_umh pid 404
[ 11.368694] Started bpfilter
[ 26.081706] audit: type=1400 audit(1596870702.078:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=505 comm="apparmor_parser"
[ 26.081873] audit: type=1400 audit(1596870702.078:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=502 comm="apparmor_parser"
[ 26.081878] audit: type=1400 audit(1596870702.078:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=502 comm="apparmor_parser"
[ 26.120196] audit: type=1400 audit(1596870702.118:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=503 comm="apparmor_parser"
[ 28.722776] audit: type=1400 audit(1596870704.722:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=507 comm="apparmor_parser"
[ 28.722785] audit: type=1400 audit(1596870704.722:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=507 comm="apparmor_parser"
[ 28.726906] audit: type=1400 audit(1596870704.726:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=504 comm="apparmor_parser"
[ 28.726911] audit: type=1400 audit(1596870704.726:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=504 comm="apparmor_parser"
[ 28.726915] audit: type=1400 audit(1596870704.726:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=504 comm="apparmor_parser"
[ 28.772069] audit: type=1400 audit(1596870704.770:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=508 comm="apparmor_parser"
[ 34.742800] kauditd_printk_skb: 2 callbacks suppressed
[ 34.742802] audit: type=1400 audit(1596870710.742:14): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=511 comm="apparmor_parser"
[ 34.742806] audit: type=1400 audit(1596870710.742:15): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=511 comm="apparmor_parser"
[ 34.766510] audit: type=1400 audit(1596870710.766:16): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=513 comm="apparmor_parser"
[ 34.766515] audit: type=1400 audit(1596870710.766:17): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=513 comm="apparmor_parser"
[ 34.766522] audit: type=1400 audit(1596870710.766:18): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=513 comm="apparmor_parser"
[ 34.899299] audit: type=1400 audit(1596870710.898:19): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=514 comm="apparmor_parser"
[ 35.034653] audit: type=1400 audit(1596870711.034:20): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=515 comm="apparmor_parser"
[ 35.058926] audit: type=1400 audit(1596870711.058:21): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/freshclam" pid=516 comm="apparmor_parser"
[ 35.124180] audit: type=1400 audit(1596870711.122:22): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=518 comm="apparmor_parser"
[ 35.158302] audit: type=1400 audit(1596870711.154:23): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=519 comm="apparmor_parser"
[ 82.581040] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 82.581042] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 82.581044] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 82.581045] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[ 86.160867] samsung_laptop: detected SABI interface: SwSmi@
[ 87.713218] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 87.716652] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 88.247673] intel_rapl_common: Found RAPL domain package
[ 88.247676] intel_rapl_common: Found RAPL domain core
[ 88.247677] intel_rapl_common: Found RAPL domain uncore
[ 88.247683] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 88.855796] ath: phy0: Set BT/WLAN RX diversity capability
[ 88.863297] ath: phy0: ASPM enabled: 0x42
[ 88.863299] ath: EEPROM regdomain: 0x65
[ 88.863299] ath: EEPROM indicates we should expect a direct regpair map
[ 88.863301] ath: Country alpha2 being used: 00
[ 88.863301] ath: Regpair used: 0x65
[ 88.864154] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 88.864646] ieee80211 phy0: Atheros AR9485 Rev:1 mem=0xffffb72a00900000, irq=16
[ 88.887810] ath9k 0000:01:00.0 wlp1s0: renamed from wlan0
[ 89.952031] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 90.199293] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 90.199297] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 90.199300] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 90.199302] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 90.199304] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 90.199307] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x19
[ 90.199310] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 90.301369] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input26
[ 90.301470] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input27
[ 90.301554] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input28
[ 138.601895] Bluetooth: Core ver 2.22
[ 138.601917] NET: Registered protocol family 31
[ 138.601918] Bluetooth: HCI device and connection manager initialized
[ 138.601923] Bluetooth: HCI socket layer initialized
[ 138.601925] Bluetooth: L2CAP socket layer initialized
[ 138.601929] Bluetooth: SCO socket layer initialized
[ 150.450452] mc: Linux media interface: v0.10
[ 159.853852] videodev: Linux video capture interface: v2.00
[ 160.195623] usbcore: registered new interface driver btusb
[ 181.957763] usbcore: registered new interface driver ath3k
[ 182.208359] usb 2-1.4: USB disconnect, device number 4
[ 182.430401] usb 2-1.4: new full-speed USB device number 5 using ehci-pci
[ 183.620068] uvcvideo: Found UVC 1.00 device WebCam SC-03FFL11739P (0ac8:c349)
[ 183.625933] uvcvideo 1-1.4:1.0: Entity type for entity Processing 2 was not initialized!
[ 183.625940] uvcvideo 1-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 183.625944] uvcvideo 1-1.4:1.0: Entity type for entity Extension 4 was not initialized!
[ 183.626150] input: WebCam SC-03FFL11739P: WebCam S as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input29
[ 183.627025] usbcore: registered new interface driver uvcvideo
[ 183.627030] USB Video Class driver (1.1.1)
[ 187.788482] usb 2-1.4: New USB device found, idVendor=0cf3, idProduct=3004, bcdDevice= 0.02
[ 187.788489] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 187.788492] usb 2-1.4: Product: Bluetooth USB Host Controller
[ 187.788496] usb 2-1.4: Manufacturer: Atheros Communications
[ 187.788499] usb 2-1.4: SerialNumber: Alaska Day 2006
[ 189.718650] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 189.718652] Bluetooth: BNEP filters: protocol multicast
[ 189.718657] Bluetooth: BNEP socket layer initialized
[ 190.770215] NET: Registered protocol family 38
[ 230.470034] kauditd_printk_skb: 25 callbacks suppressed
[ 230.470036] audit: type=1400 audit(1596870906.466:49): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=1202 comm="cups-browsed" capability=23 capname="sys_nice"
[ 230.575415] RTL8211E Gigabit Ethernet r8169-200:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[ 230.763795] r8169 0000:02:00.0 enp2s0: Link is Down
[ 233.031069] wlp1s0: authenticate with a4:2b:8c:f3:bf:42
[ 233.045664] wlp1s0: send auth to a4:2b:8c:f3:bf:42 (try 1/3)
[ 233.047652] wlp1s0: authenticated
[ 233.050366] wlp1s0: associate with a4:2b:8c:f3:bf:42 (try 1/3)
[ 233.054527] wlp1s0: RX AssocResp from a4:2b:8c:f3:bf:42 (capab=0x431 status=0 aid=1)
[ 233.054688] wlp1s0: associated
[ 233.711354] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[ 237.176477] audit: type=1400 audit(1596870913.174:50): apparmor="DENIED" operation="open" profile="snap.canonical-livepatch.canonical-livepatchd" name="/snap/core/9665/usr/share/locale/en_GB/LC_MESSAGES/snappy.mo" pid=1214 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 298.244039] [UFW BLOCK] IN=wlp1s0 OUT= MAC=e8:03:9a:c3:b0:fd:a4:2b:8c:f3:bf:42:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 334.545944] Bluetooth: RFCOMM TTY layer initialized
[ 334.545992] Bluetooth: RFCOMM socket layer initialized
[ 334.546008] Bluetooth: RFCOMM ver 1.11
[ 423.684192] [UFW BLOCK] IN=wlp1s0 OUT= MAC=e8:03:9a:c3:b0:fd:a4:2b:8c:f3:bf:42:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 430.011744] audit: type=1400 audit(1596871106.084:51): apparmor="DENIED" operation="open" profile="snap.canonical-livepatch.canonical-livepatch" name="/snap/core/9665/usr/share/locale/en_GB/LC_MESSAGES/snappy.mo" pid=2768 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 432.715973] audit: type=1400 audit(1596871108.788:52): apparmor="DENIED" operation="open" profile="snap.canonical-livepatch.canonical-livepatch" name="/snap/core/9665/usr/share/locale/en_GB/LC_MESSAGES/snappy.mo" pid=2821 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 432.819096] audit: type=1400 audit(1596871108.892:53): apparmor="DENIED" operation="open" profile="snap.canonical-livepatch.canonical-livepatch" name="/snap/core/9665/usr/share/locale/en_GB/LC_MESSAGES/snappy.mo" pid=2874 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 432.925628] audit: type=1400 audit(1596871109.000:54): apparmor="DENIED" operation="open" profile="snap.canonical-livepatch.canonical-livepatch" name="/snap/core/9665/usr/share/locale/en_GB/LC_MESSAGES/snappy.mo" pid=2926 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 509.960042] logitech-hidpp-device 0003:046D:4054.0004: HID++ 4.5 device connected.
