Your dmesg output is here:
Part1
[ 0.162988] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.162989] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.162991] system 00:05: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.162992] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.162993] system 00:05: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.162995] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.162996] system 00:05: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.162998] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.163002] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.163646] pnp: PnP ACPI: found 6 devices
[ 0.165075] thermal_sys: Registered thermal governor 'fair_share'
[ 0.165076] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.165077] thermal_sys: Registered thermal governor 'step_wise'
[ 0.165078] thermal_sys: Registered thermal governor 'user_space'
[ 0.165078] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.169576] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.169613] pci 0000:01:00.0: can't claim BAR 6 [mem 0xffff0000-0xffffffff pref]: no compatible bridge window
[ 0.169624] pci 0000:01:00.0: BAR 6: assigned [mem 0xf0680000-0xf068ffff pref]
[ 0.169626] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.169632] pci 0000:00:1c.0: bridge window [mem 0xf0600000-0xf06fffff]
[ 0.169640] pci 0000:00:1c.3: PCI bridge to [bus 02]
[ 0.169644] pci 0000:00:1c.3: bridge window [io 0x2000-0x2fff]
[ 0.169648] pci 0000:00:1c.3: bridge window [mem 0xf0500000-0xf05fffff]
[ 0.169652] pci 0000:00:1c.3: bridge window [mem 0xf0400000-0xf04fffff 64bit pref]
[ 0.169659] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.169661] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.169662] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.169663] pci_bus 0000:00: resource 7 [mem 0xdfa00000-0xfeafffff window]
[ 0.169665] pci_bus 0000:01: resource 1 [mem 0xf0600000-0xf06fffff]
[ 0.169666] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 0.169667] pci_bus 0000:02: resource 1 [mem 0xf0500000-0xf05fffff]
[ 0.169668] pci_bus 0000:02: resource 2 [mem 0xf0400000-0xf04fffff 64bit pref]
[ 0.169782] NET: Registered protocol family 2
[ 0.169961] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.169993] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.170089] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.170145] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.170187] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.170205] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.170252] NET: Registered protocol family 1
[ 0.170260] NET: Registered protocol family 44
[ 0.170271] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.170734] PCI: CLS 64 bytes, default 64
[ 0.170786] Trying to unpack rootfs image as initramfs...
[ 0.402708] Freeing initrd memory: 79840K
[ 0.402772] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.402774] software IO TLB: mapped [mem 0xcf3ef000-0xd33ef000] (64MB)
[ 0.402990] check: Scanning for low memory corruption every 60 seconds
[ 0.405217] Initialise system trusted keyrings
[ 0.405228] Key type blacklist registered
[ 0.405269] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[ 0.406728] zbud: loaded
[ 0.407119] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.407285] fuse: init (API version 7.31)
[ 0.407303] *** VALIDATE fuse ***
[ 0.407305] *** VALIDATE fuse ***
[ 0.407404] Platform Keyring initialized
[ 0.413178] Key type asymmetric registered
[ 0.413180] Asymmetric key parser 'x509' registered
[ 0.413201] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.413261] io scheduler mq-deadline registered
[ 0.413851] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.413910] vesafb: mode is 1366x768x32, linelength=5504, pages=0
[ 0.413911] vesafb: scrolling: redraw
[ 0.413912] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.413931] vesafb: framebuffer at 0xe0000000, mapped to 0x(____ptrval____), using 4160k, total 4160k
[ 0.413976] fbcon: Deferring console take-over
[ 0.413977] fb0: VESA VGA frame buffer device
[ 0.413991] intel_idle: MWAIT substates: 0x21120
[ 0.413992] intel_idle: v0.4.1 model 0x2A
[ 0.414199] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.414637] ACPI: AC Adapter [ADP1] (on-line)
[ 0.414702] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.414721] ACPI: Lid Switch [LID0]
[ 0.414752] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.414788] ACPI: Power Button [PWRB]
[ 0.414823] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.414848] ACPI: Power Button [PWRF]
[ 0.416999] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.417001] ACPI: Thermal Zone [TZ00] (70 C)
[ 0.417404] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.417405] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.417553] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.421383] Linux agpgart interface v0.103
[ 0.424203] loop: module loaded
[ 0.424499] libphy: Fixed MDIO Bus: probed
[ 0.424501] tun: Universal TUN/TAP device driver, 1.6
[ 0.424533] battery: ACPI: Battery Slot [BAT1] (battery present)
[ 0.424550] PPP generic driver version 2.4.2
[ 0.424617] VFIO - User Level meta-driver version: 0.3
[ 0.424704] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.424708] ehci-pci: EHCI PCI platform driver
[ 0.424863] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.424869] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.424883] ehci-pci 0000:00:1a.0: debug port 2
[ 0.428787] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.428801] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf070a000
[ 0.442625] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.442750] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 0.442752] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.442753] usb usb1: Product: EHCI Host Controller
[ 0.442754] usb usb1: Manufacturer: Linux 5.4.0-42-generic ehci_hcd
[ 0.442755] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.442979] hub 1-0:1.0: USB hub found
[ 0.442988] hub 1-0:1.0: 3 ports detected
[ 0.443307] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.443312] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.443326] ehci-pci 0000:00:1d.0: debug port 2
[ 0.447246] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.447261] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf0709000
[ 0.462636] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.462745] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 0.462746] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.462748] usb usb2: Product: EHCI Host Controller
[ 0.462749] usb usb2: Manufacturer: Linux 5.4.0-42-generic ehci_hcd
[ 0.462750] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.462979] hub 2-0:1.0: USB hub found
[ 0.462989] hub 2-0:1.0: 3 ports detected
[ 0.463143] ehci-platform: EHCI generic platform driver
[ 0.463163] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.463167] ohci-pci: OHCI PCI platform driver
[ 0.463178] ohci-platform: OHCI generic platform driver
[ 0.463186] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.463245] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:EPAD] at 0x60,0x64 irq 1,12
[ 0.467310] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.467315] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.467567] mousedev: PS/2 mouse device common for all mice
[ 0.468247] rtc_cmos 00:01: registered as rtc0
[ 0.468264] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.468270] i2c /dev entries driver
[ 0.468316] device-mapper: uevent: version 1.0.3
[ 0.468446] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
[ 0.468465] platform eisa.0: Probing EISA bus 0
[ 0.468466] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.468468] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.468469] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.468470] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.468471] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.468472] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.468473] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.468474] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.468475] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.468476] platform eisa.0: EISA: Detected 0 cards
[ 0.468482] intel_pstate: Intel P-state driver initializing
[ 0.468629] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.468694] drop_monitor: Initializing network drop monitor service
[ 0.468876] NET: Registered protocol family 10
[ 0.479028] Segment Routing with IPv6
[ 0.479060] NET: Registered protocol family 17
[ 0.479116] Key type dns_resolver registered
[ 0.479479] RAS: Correctable Errors collector initialized.
[ 0.479520] microcode: sig=0x206a7, pf=0x10, revision=0x2f
[ 0.479636] microcode: Microcode Update Driver: v2.2.
[ 0.479642] IPI shorthand broadcast: enabled
[ 0.479652] sched_clock: Marking stable (479384487, 224941)->(483451748, -3842320)
[ 0.479747] registered taskstats version 1
[ 0.479756] Loading compiled-in X.509 certificates
[ 0.482351] Loaded X.509 cert 'Build time autogenerated kernel key: 9e1aeb581c5145b0cc48f50fdf6e09edec23120f'
[ 0.482390] zswap: loaded using pool lzo/zbud
[ 0.482471] Key type ._fscrypt registered
[ 0.482472] Key type .fscrypt registered
[ 0.492163] Key type big_key registered
[ 0.496782] Key type encrypted registered
[ 0.496787] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.496795] ima: No TPM chip found, activating TPM-bypass!
[ 0.496804] ima: Allocated hash algorithm: sha1
[ 0.496812] ima: No architecture policies found
[ 0.496822] evm: Initialising EVM extended attributes:
[ 0.496822] evm: security.selinux
[ 0.496823] evm: security.SMACK64
[ 0.496824] evm: security.SMACK64EXEC
[ 0.496824] evm: security.SMACK64TRANSMUTE
[ 0.496825] evm: security.SMACK64MMAP
[ 0.496825] evm: security.apparmor
[ 0.496826] evm: security.ima
[ 0.496826] evm: security.capability
[ 0.496827] evm: HMAC attrs: 0x1
[ 0.497211] PM: Magic number: 12:314:42
[ 0.497222] bdi 7:7: hash matches
[ 0.497329] rtc_cmos 00:01: setting system clock to 2020-07-31T19:00:49 UTC (1596222049)
[ 0.498715] Freeing unused decrypted memory: 2040K
[ 0.499222] Freeing unused kernel image memory: 2712K
[ 0.502204] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.526671] Write protecting the kernel read-only data: 22528k
[ 0.527243] Freeing unused kernel image memory: 2008K
[ 0.527484] Freeing unused kernel image memory: 1192K
[ 0.539461] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.539463] x86/mm: Checking user space page tables
[ 0.551232] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.551235] Run /init as init process
[ 0.683129] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20190816/utaddress-204)
[ 0.683140] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.683146] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 0.683151] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.683153] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 0.683158] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.683160] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 0.683164] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.683165] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 0.687730] ahci 0000:00:1f.2: version 3.0
[ 0.687915] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.689872] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 0.693662] libphy: r8169: probed
[ 0.693965] r8169 0000:02:00.0 eth0: RTL8168evl/8111evl, 24:f5:aa:c4:cc:2f, XID 2c9, IRQ 27
[ 0.693968] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.702549] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x5 impl SATA mode
[ 0.702553] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 0.702629] cryptd: max_cpu_qlen set to 1000
[ 0.715478] scsi host0: ahci
[ 0.716395] scsi host1: ahci
[ 0.716541] scsi host2: ahci
[ 0.719517] scsi host3: ahci
[ 0.726587] scsi host4: ahci
[ 0.727271] scsi host5: ahci
[ 0.727356] ata1: SATA max UDMA/133 abar m2048@0xf0708000 port 0xf0708100 irq 26
[ 0.727358] ata2: DUMMY
[ 0.727361] ata3: SATA max UDMA/133 abar m2048@0xf0708000 port 0xf0708200 irq 26
[ 0.727362] ata4: DUMMY
[ 0.727363] ata5: DUMMY
[ 0.727364] ata6: DUMMY
[ 0.742088] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 0.753086] checking generic (e0000000 410000) vs hw (e0000000 10000000)
[ 0.753088] fb0: switching to inteldrmfb from VESA VGA
[ 0.753153] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 0.762546] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.762548] [drm] Driver supports precise vblank timestamp query.
[ 0.767387] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 0.794541] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.798634] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.861526] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[ 0.862677] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 0.863062] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[ 0.898795] fbcon: i915drmfb (fb0) is primary device
[ 0.898796] fbcon: Deferring console take-over
[ 0.898799] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[ 0.951443] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.951445] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.951738] hub 1-1:1.0: USB hub found
[ 0.951819] hub 1-1:1.0: 6 ports detected
[ 0.954914] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.954916] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.955063] hub 2-1:1.0: USB hub found
[ 0.955163] hub 2-1:1.0: 6 ports detected
[ 1.042635] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.046700] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.053169] ata1.00: ATA-8: ST500LM012 HN-M500MBB, 2AR10002, max UDMA/133
[ 1.053172] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.055124] ata3.00: ATAPI: TSSTcorp CDDVDW SN-208BB, SC00, max UDMA/100
[ 1.057204] ata3.00: configured for UDMA/100
[ 1.059591] ata1.00: configured for UDMA/133
[ 1.060004] scsi 0:0:0:0: Direct-Access ATA ST500LM012 HN-M5 0002 PQ: 0 ANSI: 5
[ 1.060263] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.060345] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 1.060348] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.060383] sd 0:0:0:0: [sda] Write Protect is off
[ 1.060386] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.060422] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.062083] scsi 2:0:0:0: CD-ROM TSSTcorp CDDVDW SN-208BB SC00 PQ: 0 ANSI: 5
[ 1.115971] sda: sda1
[ 1.116462] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.148158] sr 2:0:0:0: [sr0] scsi3-mmc drive: 16x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.148165] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.171034] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 1.171143] sr 2:0:0:0: Attached scsi generic sg1 type 5
[ 1.238562] usb 1-1.2: new full-speed USB device number 3 using ehci-pci
[ 1.242612] usb 2-1.4: new full-speed USB device number 3 using ehci-pci
[ 1.328340] random: fast init done
[ 1.350018] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 1.350025] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.350029] usb 1-1.2: Product: USB Receiver
[ 1.350032] usb 1-1.2: Manufacturer: Logitech
[ 1.350337] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.350347] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.350367] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.357623] usb 2-1.4: New USB device found, idVendor=0cf3, idProduct=3004, bcdDevice= 0.02
[ 1.357626] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.357628] usb 2-1.4: Product: Bluetooth USB Host Controller
[ 1.357630] usb 2-1.4: Manufacturer: Atheros Communications
[ 1.357632] usb 2-1.4: SerialNumber: Alaska Day 2006
[ 1.357662] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.364340] usbcore: registered new interface driver usbhid
[ 1.364342] usbhid: USB HID core driver
[ 1.367445] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C534.0001/input/input7
[ 1.406566] tsc: Refined TSC clocksource calibration: 2394.559 MHz
[ 1.406586] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2284235ba97, max_idle_ns: 440795203400 ns
[ 1.406696] clocksource: Switched to clocksource tsc
[ 1.426943] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.0-1.2/input0
[ 1.427288] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/input/input8
[ 1.427492] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/input/input9
[ 1.434622] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
[ 1.486766] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/input/input10
[ 1.486918] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.0-1.2/input1
[ 1.555140] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.0-1.2/input0
[ 1.569851] usb 1-1.4: New USB device found, idVendor=0ac8, idProduct=c349, bcdDevice= 0.15
[ 1.569858] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.569862] usb 1-1.4: Product: WebCam SC-03FFL11739P
[ 1.569865] usb 1-1.4: Manufacturer: Vimicro Corp.
[ 1.574484] psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x350f00)
[ 1.590298] psmouse serio1: elantech: Synaptics capabilities query result 0x08, 0x17, 0x0c.
[ 1.605593] psmouse serio1: elantech: Elan sample query result 01, 22, 85
[ 1.687330] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input5
[ 1.719172] logitech-djreceiver 0003:046D:C534.0002: hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.0-1.2/input1
[ 1.779990] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
[ 1.780639] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input13
[ 1.780791] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input14
[ 1.780890] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input15
[ 1.780994] hid-generic 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:1a.0-1.2/input1:1
[ 1.781990] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
[ 1.782377] input: Logitech Wireless Mouse PID:4054 Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input20
[ 1.782551] hid-generic 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4054] on usb-0000:00:1a.0-1.2/input1:2
[ 1.912384] input: Logitech Wireless Keyboard PID:4023 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input24
[ 1.912550] logitech-hidpp-device 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:00:1a.0-1.2/input1:1
[ 1.952249] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input25
[ 1.952503] logitech-hidpp-device 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:1a.0-1.2/input1:2
[ 2.543532] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.861875] random: crng init done
[ 4.861882] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.212071] systemd[1]: Inserted module 'autofs4'
[ 5.490078] systemd[1]: systemd 245.4-4ubuntu3.2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 5.506743] systemd[1]: Detected architecture x86-64.
[ 5.562758] systemd[1]: Set hostname to <saptarshi-300E4C-300E5C-300E7C>.
[ 8.379518] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[ 9.077683] systemd[1]: Created slice system-modprobe.slice.
[ 9.077958] systemd[1]: Created slice User and Session Slice.
[ 9.078040] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.078308] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.078353] systemd[1]: Reached target User and Group Name Lookups.
[ 9.078368] systemd[1]: Reached target Remote File Systems.
[ 9.078385] systemd[1]: Reached target Slices.
[ 9.078583] systemd[1]: Listening on Syslog Socket.
[ 9.078694] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.078763] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.078985] systemd[1]: Listening on Journal Audit Socket.
[ 9.079085] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.079211] systemd[1]: Listening on Journal Socket.
[ 9.079329] systemd[1]: Listening on udev Control Socket.
[ 9.079423] systemd[1]: Listening on udev Kernel Socket.
[ 9.080463] systemd[1]: Mounting Huge Pages File System...
[ 9.081665] systemd[1]: Mounting POSIX Message Queue File System...
[ 9.083385] systemd[1]: Mounting Kernel Debug File System...
[ 9.084837] systemd[1]: Mounting Kernel Trace File System...
[ 9.086561] systemd[1]: Starting Journal Service...
[ 9.087820] systemd[1]: Starting Set the console keyboard layout...
[ 9.089119] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 9.089208] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 9.149179] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.149241] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.273263] systemd[1]: Starting Load Kernel Modules...
[ 9.274714] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 9.275871] systemd[1]: Starting udev Coldplug all Devices...
[ 9.277185] systemd[1]: Starting Uncomplicated firewall...
[ 9.279267] systemd[1]: Mounted Huge Pages File System.
[ 9.279450] systemd[1]: Mounted POSIX Message Queue File System.
[ 9.279597] systemd[1]: Mounted Kernel Debug File System.
[ 9.279742] systemd[1]: Mounted Kernel Trace File System.
[ 9.280271] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 9.372301] systemd[1]: Started Journal Service.
[ 9.510335] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 10.193551] systemd-journald[366]: Received client request to flush runtime journal.
[ 10.274566] Adding 2097148k swap on /swapfile. Priority:-2 extents:6 across:2260988k FS
[ 10.846926] lp: driver loaded but no devices found
[ 11.038286] ppdev: user-space parallel port driver
[ 11.127297] bpfilter: Loaded bpfilter_umh pid 395
[ 11.127629] Started bpfilter
[ 16.866163] audit: type=1400 audit(1596222065.861:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=493 comm="apparmor_parser"
[ 16.866168] audit: type=1400 audit(1596222065.861:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=493 comm="apparmor_parser"
[ 16.907621] audit: type=1400 audit(1596222065.905:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=494 comm="apparmor_parser"
[ 16.921447] audit: type=1400 audit(1596222065.917:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=496 comm="apparmor_parser"
[ 17.215634] audit: type=1400 audit(1596222066.213:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=499 comm="apparmor_parser"
[ 17.310609] audit: type=1400 audit(1596222066.309:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=498 comm="apparmor_parser"
[ 17.310616] audit: type=1400 audit(1596222066.309:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=498 comm="apparmor_parser"
[ 17.314776] audit: type=1400 audit(1596222066.313:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=495 comm="apparmor_parser"
