Since a few days I can't play videos, system wide.
I am running this help: So installieren Sie alle Multimedia-Codecs unter Ubuntu Linux | CodePre.com
Then the videos work again for a short time, but then not again.
How can I fix this error?
Hello greenster
Have you tried using "vlc"?
Yes, VLC plays videos, but no videos are played in several browsers.
Hi Greenster,
If you can't watch youtube, it is definitely not a 'ubuntu-restricted-extras' problem.
If you disable video hardware acceleration in your browser settings and it is still not working then we really need more info.
To get some extra info, run the following commands and paste the results here, we might need more later on:
inxi -CGz
snap list
dpkg --get-selections {*firefox*,*brave*,*chromium*,*opera*}
cat /etc/*release
The info we get from the aforementioned commands could at least give us some insight in what kind of install we are looking at.
Thank you very much for your help. But strangely enough, it currently works to watch YouTube and other videos. If the error occurs again, then I will implement your suggestions. I use Vivaldi browser as default, but also Firefox and Chromium for testing.
The error occurs again.
CPU:
Info: quad core model: AMD A12-9800E RADEON R7 12 COMPUTE CORES 4C+8G
bits: 64 type: MT MCP cache: L2: 2 MiB
Speed (MHz): avg: 1390 min/max: 800/3100 cores: 1: 1386 2: 1398 3: 1393
4: 1386
Graphics:
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] driver: amdgpu v: kernel
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD CARRIZO (LLVM 13.0.1 DRM 3.42 5.15.0-39-generic)
v: 4.6 Mesa 22.0.1
Name Version Revision Tracking Herausgeber Hinweise
bare 1.0 5 latest/stable canonicalâś“ base
canonical-livepatch 10.2.3 146 latest/stable canonicalâś“ -
chromium 102.0.5005.115 2011 latest/stable canonicalâś“ -
core 16-2.56 13308 latest/stable canonicalâś“ core
core18 20220428 2409 latest/stable canonicalâś“ base
core20 20220527 1518 latest/stable canonicalâś“ base
curl 7.83.1 991 latest/stable woutervb -
emote 3.0.3 19 latest/stable tom-james-watson -
gnome-3-28-1804 3.28.0-19-g98f9e67.98f9e67 161 latest/stable canonicalâś“ -
gnome-3-38-2004 0+git.09fbd6c 106 latest/stable/… canonical✓ -
gtk-common-themes 0.1-79-ga83e90c 1534 latest/stable/… canonical✓ -
snapd 2.56 16010 latest/stable canonicalâś“ snapd
snapd-desktop-integration 0.1 14 latest/stable/… canonical✓ -
software-boutique 0+git.0fdcecc 57 latest/stable/… flexiondotorg classic
ubuntu-mate-welcome 22.04.0-5b7bef38 709 latest/stable/… flexiondotorg classic
firefox install
dpkg: Kein Paket gefunden, das auf *brave* passt
chromium-browser install
chromium-codecs-ffmpeg-extra install
dpkg: Kein Paket gefunden, das auf *opera* passt
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=22.04
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION="Ubuntu 22.04 LTS"
PRETTY_NAME="Ubuntu 22.04 LTS"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04 LTS (Jammy Jellyfish)"
VERSION_CODENAME=jammy
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=jammy
Hi greenster
I've more or less simulated your setup on an old laptop.
The first time I started Firefox (snap) and visited youtube, it refused to connect to youtube and displayed a certificate error, hence I couldn't connect and I couldn't watch video.
Exactly the same happened to chromium.
Some time later it just worked.
With the small amount of info that I have I suspect that this is a certificate- or https handshake error where I presume that the communication with the certificate-issuing party times out or something comparable. So I have some questions:
If it happens again with youtube, could you try to see if Odysee has the same problem ?
If youtube refuses to play on your browsers
Could you try to let your browsers play a locally stored video instead of an online one ?
(only use WEBM videos or , if you dont have locally stored WEBM, a youtube compatible format like MP4 containing AVC + AAC )
It would confirm the suspicion that the problem is network related.
Has your internetspeed been fluctuating more than ever recently ?
Has there been any machines digging in the streets in your neighbourhood ?
Is there any specific day ( or time ) that your videoplay stops/starts working (rush hour)?
Have you visited any more sites lately that gave a certificate error ?
Only VLC plays videos offline.
Odysee is like youtube but a lot less demanding with respect to javascript, beacons, XHR etc etc. So if something doesn't work with Odysee it will probably work nowhere
Odysee also does not play videos.
Is it possible that my graphics card has a problem?
Okay, so your browsers don't play any online videos but also no offline videos.
VLC (and probably other mediaplayers too) play without problem.
Since the mediaplayers play video, your standard codecs are provably working and so is the rendering path to your video output. (so it is not a graphics card problem)
Browsers need codecs as prepackaged browser-addons (almost always prepackaged with the browser). I am afraid that I'm no expert on that. Sorry.
Last resort:
sudo apt install ubuntu-restricted-addons
If that doesn't work, I'm out of solutions, I give up.
"sudo apt install ubuntu-restricted-addons" was already installed, but thanks for your help.
I enabled pre-release updates and after that there was a big update and now the videos in the browser play again
