Hi
New to mate.
I installed ver 14.02 in a virtual box.
I can not get the screen resolution to change from 640x480.
I have virtual box extentions installed and working on other linux flavors.
I was able to install all updates, but still no luck.
I also did the sudo get install virtual box x11.
How do I get this fixed or working? 640x480 just not cutting it, can not even scroll through a lot of boxes.
TIA
