Output/result of “cvlc -vvv —zoom=0.5 filename”
Its worth noting that it normally opens in a reduced size of screen and when the “zoom=0.5” is employed it occupies about a 12th of the screen. The jumpiness goes away and the sound is almost in sync (there are still warnings) but when you try to drag the frame to expand the image it drops frames and the jumpiness returns, see output:
[00007facce225828] avcodec decoder warning: plane 0 not aligned
[00007facce225828] avcodec decoder warning: disabling direct rendering
[00007facb4001e88] xcb_window window error: X server failure
[00007facbc00ed58] core video output warning: picture is too late to be displayed (missing 165 ms)
[00007facbc00ed58] core video output warning: picture is too late to be displayed (missing 125 ms)
[00007facbc00ed58] core video output warning: picture is too late to be displayed (missing 86 ms)
[00007facbc00ed58] core video output warning: picture is too late to be displayed (missing 46 ms)
[00007facbc00ed58] core video output debug: picture might be displayed late (missing 6 ms)
X Error of failed request: BadDrawable (invalid Pixmap or Window parameter)
Major opcode of failed request: 72 (X_PutImage)
Resource id in failed request: 0x3400000
Serial number of failed request: 22743
Current serial number in output stream: 22745
Rather oddly gnome-mplayer renders the video much better with just a bit of lag on the audio. While my graphics are a little crude to say the least it does suggest all is not well with this version vlc. Oh yes as the picture gets bigger the more the cpu maxes out (Intel® Core™2 CPU).
Heathrobinson.
