@Gordon:
OK, here's the .xsession-errors.old. I just found the control missing, logged off and back on.
<deleted first part, hope I left the interesting stuff for you.>
###!!! [Parent][RunMessage] Error: Channel closing: too late to send/recv, messages will be lost
(mate-screensaver:1737): GLib-CRITICAL **: 08:52:50.111: Source ID 151 was not found when attempting to remove it
(mate-power-manager:1695): GLib-CRITICAL **: 09:43:04.347: Source ID 1852 was not found when attempting to remove it
(mate-screensaver:1737): GLib-CRITICAL **: 11:01:30.352: Source ID 185 was not found when attempting to remove it
(mate-power-manager:1695): GLib-CRITICAL **: 12:05:55.235: Source ID 1949 was not found when attempting to remove it
Gtk-Message: 12:20:42.114: GtkDialog mapped without a transient parent. This is discouraged.
RuntimeError: object at 0x7fab23749c30 of type FolderColorMenu is not initialized
RuntimeError: object at 0x7fab23749410 of type RenameMenu is not initialized
(caja:1592): Gtk-CRITICAL **: 12:21:01.932: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(caja:1592): Gtk-CRITICAL **: 12:21:01.933: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(caja:1592): Gtk-CRITICAL **: 12:21:01.934: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(mate-screensaver:1737): GLib-CRITICAL **: 13:11:19.442: Source ID 222 was not found when attempting to remove it
(mate-power-manager:1695): GLib-CRITICAL **: 13:47:19.588: Source ID 2043 was not found when attempting to remove it
javaldx: Could not find a Java Runtime Environment!
Please ensure that a JVM and the package libreoffice-java-common
is installed.
If it is already installed then try removing ~/.libreoffice/3/user/config/javasettings_Linux_*.xml
Warning: failed to read path from javaldx
func=xmlSecCheckVersionExt:file=xmlsec.c:line=188:obj=unknown:subj=unknown:error=19:invalid version:mode=abi compatible;expected minor version=2;real minor version=2;expected subminor version=25;real subminor version=26
(caja:1592): Gtk-CRITICAL **: 14:09:34.112: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(caja:1592): Gtk-CRITICAL **: 14:09:34.119: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(caja:1592): Gtk-CRITICAL **: 14:09:34.120: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(process:1764): indicator-sound-WARNING **: 14:10:24.955: accounts-service-access.vala:218: unable to sync volume 1.219890 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 14:10:26.667: accounts-service-access.vala:218: unable to sync volume 0.610062 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 14:10:45.516: accounts-service-access.vala:218: unable to sync volume 0.457539 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 14:10:46.666: accounts-service-access.vala:218: unable to sync volume 0.915024 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x6200004 (Image View)
Window manager warning: meta_window_activate called by a pager with a 0 timestamp; the pager needs to be fixed.
(nm-applet:1670): Gtk-CRITICAL **: 14:51:29.285: gtk_widget_destroy: assertion 'GTK_IS_WIDGET (widget)' failed
(nm-applet:1670): Gtk-WARNING **: 14:51:29.294: Can't set a parent on widget which has a parent
(nm-applet:1670): Gtk-CRITICAL **: 14:55:44.835: gtk_widget_destroy: assertion 'GTK_IS_WIDGET (widget)' failed
(nm-applet:1670): Gtk-WARNING **: 14:55:44.840: Can't set a parent on widget which has a parent
Window manager warning: Invalid WM_TRANSIENT_FOR window 0x6a0000e specified for 0x6a0000c (calibre).
(caja:1592): Gtk-CRITICAL **: 15:54:15.322: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(caja:1592): Gtk-CRITICAL **: 15:54:15.323: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(process:1764): indicator-sound-WARNING **: 16:14:03.588: accounts-service-access.vala:218: unable to sync volume 0.855026 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 16:14:04.667: accounts-service-access.vala:218: unable to sync volume 0.615036 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 17:01:47.062: accounts-service-access.vala:218: unable to sync volume 0.767558 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 17:01:48.665: accounts-service-access.vala:218: unable to sync volume 0.920059 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 17:02:50.286: accounts-service-access.vala:218: unable to sync volume 0.767537 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 17:02:51.666: accounts-service-access.vala:218: unable to sync volume 0.767532 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 17:03:17.090: accounts-service-access.vala:218: unable to sync volume 0.533493 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
[Child 12198, MediaDecoderStateMachine #1] WARNING: Decoder=7fbc5e12f400 Decode error: NS_ERROR_DOM_MEDIA_FATAL_ERR (0x806e0005) - RefPtrMediaSourceTrackDemuxer::SamplesPromise mozilla::MediaSourceTrackDemuxer::DoGetSamples(int32_t): manager is detached.: file /builds/worker/checkouts/gecko/dom/media/MediaDecoderStateMachine.cpp, line 3470
[Child 14465, MediaDecoderStateMachine #1] WARNING: Decoder=7ff6d0155800 Decode error: NS_ERROR_DOM_MEDIA_FATAL_ERR (0x806e0005) - RefPtrMediaSourceTrackDemuxer::SamplesPromise mozilla::MediaSourceTrackDemuxer::DoGetSamples(int32_t): manager is detached.: file /builds/worker/checkouts/gecko/dom/media/MediaDecoderStateMachine.cpp, line 3470
(process:1764): indicator-sound-WARNING **: 17:10:20.782: accounts-service-access.vala:218: unable to sync volume 0.767532 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x3e00003 (Control Ce)
(process:1764): indicator-sound-WARNING **: 18:11:08.140: accounts-service-access.vala:218: unable to sync volume 0.762604 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
Gtk-Message: 18:13:17.820: GtkDialog mapped without a transient parent. This is discouraged.
Gtk-Message: 18:16:58.951: GtkDialog mapped without a transient parent. This is discouraged.
Gtk-Message: 18:17:05.233: GtkDialog mapped without a transient parent. This is discouraged.
(mate-terminal:16368): dbind-WARNING **: 18:44:54.065: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
(mate-screensaver:1737): GLib-CRITICAL **: 19:22:46.242: Source ID 270 was not found when attempting to remove it
(/usr/lib/mate-screensaver/mate-screensaver-gl-helper:16738): dbind-WARNING **: 19:22:56.441: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
(mate-power-manager:1695): GLib-CRITICAL **: 22:03:18.805: Source ID 2470 was not found when attempting to remove it
(mate-screensaver:1737): GLib-CRITICAL **: 22:47:31.919: Source ID 304 was not found when attempting to remove it
(/usr/lib/mate-screensaver/mate-screensaver-gl-helper:18448): dbind-WARNING **: 22:47:42.022: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
(mate-power-manager:1695): GLib-CRITICAL **: 06:32:11.612: Source ID 2587 was not found when attempting to remove it
(mate-terminal:23071): dbind-WARNING **: 06:37:53.157: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
is installed.
(soffice:23197): dbind-WARNING **: 06:46:12.467: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
(mate-volume-control:23379): dbind-WARNING **: 06:51:17.166: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
Gtk-Message: 06:51:18.231: GtkDialog mapped without a transient parent. This is discouraged.
(caja:1592): Gtk-CRITICAL **: 06:52:20.552: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
(caja:1592): Gtk-CRITICAL **: 06:52:20.553: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
[Child 23311, MediaDecoderStateMachine #1] WARNING: Decoder=7f834d3e9c00 Decode error: NS_ERROR_DOM_MEDIA_FATAL_ERR (0x806e0005) - RefPtrMediaSourceTrackDemuxer::SamplesPromise mozilla::MediaSourceTrackDemuxer::DoGetSamples(int32_t): manager is detached.: file /builds/worker/checkouts/gecko/dom/media/MediaDecoderStateMachine.cpp, line 3470
Window manager warning: Invalid WM_TRANSIENT_FOR window 0x5400005 specified for 0x5400004 (Initializi).
(mate-terminal:25161): dbind-WARNING **: 10:01:51.246: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
Gtk-Message: 10:06:21.282: GtkDialog mapped without a transient parent. This is discouraged.
(mate-display-properties:25349): dbind-WARNING **: 10:06:54.484: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
Gtk-Message: 10:06:54.807: GtkDialog mapped without a transient parent. This is discouraged.
Gtk-Message: 10:07:04.007: GtkDialog mapped without a transient parent. This is discouraged.
[Child 9930, MediaDecoderStateMachine #1] WARNING: Decoder=7f454f8d3000 Decode error: NS_ERROR_DOM_MEDIA_FATAL_ERR (0x806e0005) - RefPtrMediaSourceTrackDemuxer::SamplesPromise mozilla::MediaSourceTrackDemuxer::DoGetSamples(int32_t): manager is detached.: file /builds/worker/checkouts/gecko/dom/media/MediaDecoderStateMachine.cpp, line 3470
(mate-display-properties:26661): dbind-WARNING **: 11:01:38.806: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
Gtk-Message: 11:01:40.340: GtkDialog mapped without a transient parent. This is discouraged.
Gtk-Message: 11:01:53.730: GtkDialog mapped without a transient parent. This is discouraged.
Gtk-Message: 11:04:25.241: GtkDialog mapped without a transient parent. This is discouraged.
(mate-terminal:26797): dbind-WARNING **: 11:04:44.416: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-Mmv4oIaztb: Connection refused
(mate-terminal:26797): GLib-GObject-CRITICAL **: 11:04:47.653: g_object_set_data: assertion 'G_IS_OBJECT (object)' failed
(process:1764): indicator-sound-WARNING **: 11:42:54.080: accounts-service-access.vala:218: unable to sync volume 0.915126 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(process:1764): indicator-sound-WARNING **: 11:42:55.667: accounts-service-access.vala:218: unable to sync volume 1.067627 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
Gtk-Message: 11:43:41.880: GtkDialog mapped without a transient parent. This is discouraged.
Gtk-Message: 11:43:46.259: GtkDialog mapped without a transient parent. This is discouraged.
(mate-session:1411): Gtk-WARNING **: 11:43:46.342: gtk_window_set_titlebar() called on a realized window
Gtk-Message: 11:43:46.398: GtkDialog mapped without a transient parent. This is discouraged.
Window manager warning: CurrentTime used to choose focus window; focus window may not be correct.
Window manager warning: Got a request to focus the no_focus_window with a timestamp of 0. This shouldn't happen!
IPDL protocol error: Handler returned error code!
###!!! [Parent][DispatchAsyncMessage] Error: PLayerTransaction::Msg_ReleaseLayer Processing error: message was deserialized, but the handler returned false (indicating failure)
(firefox:2223): GLib-GObject-WARNING **: 11:44:02.043: invalid (NULL) pointer instance
(firefox:2223): GLib-GObject-CRITICAL **: 11:44:02.044: g_signal_handler_disconnect: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(firefox:2223): GLib-GObject-WARNING **: 11:44:02.044: invalid (NULL) pointer instance
(firefox:2223): GLib-GObject-CRITICAL **: 11:44:02.047: g_signal_handler_disconnect: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
Gdk-Message: 11:44:02.179: mate-screensaver: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Gdk-Message: 11:44:02.187: firefox: Fatal IO error 25 (Inappropriate ioctl for device) on X server :0.
Gdk-Message: 11:44:02.181: /home/fredex/Downloads/firefox/firefox/firefox-bin: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Gdk-Message: 11:44:02.240: mate-maximus: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Gdk-Message: 11:44:02.223: update-notifier: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Gdk-Message: 11:44:02.410: blueman-applet: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Gdk-Message: 11:44:02.460: nm-applet: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Exiting due to channel error.
Sandbox: Unexpected EOF, op 2 flags 00 path /etc/localtime
Gdk-Message: 15:44:02.205: /home/fredex/Downloads/firefox/firefox/firefox-bin: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Sandbox: Unexpected EOF, op 0 flags 02000000 path /etc/localtime
Gdk-Message: 15:44:02.444: /home/fredex/Downloads/firefox/firefox/firefox-bin: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Gdk-Message: 15:44:02.431: /home/fredex/Downloads/firefox/firefox/firefox-bin: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
