Hello,
I found a small bug or incompatibility. On my Corsair K90 keyboard I have a scroll-wheel for controlling volume; in 16.04 volume up (scrolling up) doesn’t work (scrolling down to turn down the volume works however). It works fine in Windows and it worked fine in 15.10.
If there is a solution to the problem then I would be very grateful
Cheers
