sudo systemctl enable bluetooth.service
[sudo] password for andy:
Synchronizing state of bluetooth.service with SysV service script with /usr/lib/systemd/systemd-sysv-install.
Executing: /usr/lib/systemd/systemd-sysv-install enable bluetooth
~$ sudo systemctl start bluetooth.service
~$ rfkill
ID TYPE DEVICE SOFT HARD
0 wlan phy0 unblocked unblocked
1 bluetooth hci0 unblocked unblocked
~$ rfkill
It looks like it can not connect?
Ctrl C does not exit out.
bluetoothctl Waiting to connect to bluetoothd...[bluetooth]# Agent registered [bluetooth]
This is quite a challenge. Did anyone else have this hard a time with getting bluetooth going?
My best bet is to restart the Echo device you are trying to pair and try and see if the device has some buttons that operate with bluetooth - mainly is there any reset option to return the settings to factory defaults just in case - somehow restarting and resetting just fixes all the issues, don't know why but that usually works the best
Also check in your bluetooth gui app if you can search for the device there on your computer gui - you should have an option to see devices ready to pair up
And also - if you've got a smartphone/iphone try to turn the bluetooth on the phone and see if you can see your desktop in the bluetooth options as recommended device you can pair - phone should be able to see your device if I'm not mistaken
