Wake On Lan GUI tool for Ubuntu Mate
Does anyone know of a GUI tool I can use from Mate to wake my servers?
I can easily do it from Android with a App from the play store but I cant seem to find one for Linux.
I don’t want to use the command line I just want a easy GUI tool to do this.
Any suggestions?
Thanks
You can try gWakeOnLAN.
The application is available for all current Ubuntu versions. You can install it with:
sudo apt-get install gwakeonlan
It looks simple:
Awesome thanks for the help!
I want to start a NAS using WOL, but my NAS needs to receive a WOL packet every 3 minutes to keep alive. I'm looking for GUI (I'm nobel in Ubuntu) with this function. All GUIs I try only send a unique WOL packet, and after 3min the NAS goes to power off state.
Any suggestions?
Thanks in advance.
