The below link contains my guidance in response to whether it is best to use PNG or JPEG as the format for wallpaper image files.
That post is so perfect, straight-to-the-point and complete that I hope you don't mind me quoting it here ad verbatim because it might be helpful to others:
Basically, whether you use
- a “raw” format like PNG, or
- a “compressed” format like JPEG,
there is no in-memory performance difference, once it is loaded!
- They will BOTH use up exactly the same total memory bits to correspond to the image pixel count (xxxx wide by yyyy tall).
The only difference, performance-wise, is the load time, which is a single hit at initial load. The larger the file, the longer to load from disk to memory. The other consideration is that a compressed image, depending on complexity, could itself also take a long time to be processed to transfrom from compressed to decompressed (a.k.a. “raw”) form which is then kept as “persistent” memory-resident format. The disadvantage of a compressed image has nothing to do with performance … and all to do with re-composition quality.
So in the end, it only boils down to whichever format is simpler for you to manage, based on your prioritizing and doing the trade-off of
- image file quality at display, vs
- storage size on disk.
I also second what you mentioned earlier in that post
- load time (specifically when creating a background image based slideshow on a slow rig)
