Weather applets inop
Same as @acutbal here. No Clock no Weather Report after update.
16.04 on the Mate 1.14.1 PPA.
The update:
Upgraded the following packages:
libmateweather-common (1.14.0-1~xenial1.01) to 1.14.1-1~xenial1.0
libmateweather1 (1.14.0-1~xenial1.01) to 1.14.1-1~xenial1.0
Package update coming soon…
After the upgrade I do not have the time or date applet.
This morning’s update didn’t fix the issue
I know. I made a bollocks of the update :persevere:
New packages have built in the PPA and will publish soon. They will fix the weather service issue and actually work again :slight_smile:
And they are ready, for those of you using the xenial-mate PPA.
sudo apt update
sudo apt upgrade
Solved. Thank you.:smile:
Thank you for the fix, worked on my computer Virginia, United States
I’m not certain that everything is back to normal however
Forecast not currently available for this location.
weather location = Washington DC Dulles International Airport.
Still same problem. May have fixed the service but this applet is still a disservice to Ubuntu-MATE quality elsewhere. The locations are the same, despite the service being able to report on weather from around the globe. Probably the locations list is also hard-coded(!) into the applet, just like the weather service was.
Useless and badly coded. And I won’t report a bug in protest! I don’t think anyone needs to be told how you should not hardcode this type of data. I’ll keep using other third-party applets for weather reporting until someone realizes the world is bigger than that ridiculous list.
Edit: sorry for the rant and all the negativity. But it’s frustrating. Never mind me.
Fixed!!
Thank you very much!! :grin:
Nope, still not working
Log out and in again after updating.
@Wimpy Is the new version coming to UM 14.04?
I do not see the update (main server US)
Works great, now, on xenial-mate PPA. Second time’s a charm. :joy:
Same here, second time's a charm. So now to wait for it to filter down to the 1.12 desktop :slight_smile:
But no forecast
1.12 will take some time, because it has to be SRU’d.
I don’t know what you mean by xenial-mate PPA, It’s not available on the manu. I’m using Server for United States
This PPA needs to be installed.
And you end up with the 1.12 desktop being replaced with 1.14.
Same and trying around the globe I find no forecasts anywhere.
