I’ve got a desktop backround left after running that command…This machine is terminal only now…reinstalling same files didn’t revert it to it’s previous (semi-broken) state
Ouch, thats kinda what it i was afraid of. Sorry that happened to you but i appreciate the heads up @psfal
Ouch! No, no. That is not safe. Don’t do it!
Sheesh! When I advised you that I didn’t think of checking it myself. It would have never crossed my mind those type of dependencies. Some of those are actually ok. mate-desktop-environment-core and ubuntu-mate-core are safe to remove meta-packages. But the rest no.
What a complete nonsense! I’m even feeling slightly ashamed I’m seeing that. Those dependencies are ridiculous!.. It’s a bloody weather applet! I’m feeling ashamed of using MATE today.
@psfal
I can’t express how sorry I am I forced you into this
Nobody forced me to do anything…I took a risk and it didn’t play out well…no sweat, I’ve had worse set-backs
Any suggestions from this point though? Or am I looking at a reinstall
Yes. You can just reinstall the removed packages. Check the list provided by @mauimate. Hopefully that will restore everything back to normal.
I’ll give that a try, thanks
I’ve got GUI back, I can live with this until the fix comes. Thanks
I recently upgraded my Ubuntu Mate 16.04 to Mate Xenial. I followed
instructions from
https://launchpad.net/~ubuntu-mate-dev/+archive/ubuntu/xenial-mate
Everything was fine but my clock applet now crashes like:
/usr/lib/mate-panel/clock-applet
(clock-applet:9436): Gtk-ERROR **: GTK+ 2.x symbols detected. Using
GTK+ 2.x and GTK+ 3 in the same process is not supported
Trace/breakpoint trap (core dumped)
I googled without success. I really do not know what to do. Please help
Looks like a bug:
from https://launchpad.net/~ubuntu-mate-dev/+archive/ubuntu/xenial-mate:
… The version of MATE 1.14 in this PPA is built against GTK2+ …
however:
$ ldd libmateweather.so.1.6.9 | grep gtk
libgtk-3.so.0 => /usr/lib/x86_64-linux-gnu/libgtk-3.so.0 (0x00007f0515a6d000)
I am not completely sure but possible solution (until they make a new version) could be to replace the /usr/lib/x86_64-linux-gnu/libmateweather.so.1.6.9 with file from the previous version (1.14.1-1~xenial1.1). This version is built against GTK2+ and works. I know this because I have another machine where Mate Xenial was installed several days ago.
I tried this also (before you postet this).
After deinstalled libmateweather1 and libmateweather-common i wasn’t able to log in.
So i startet Linux in Recovery mode (pressing ESC while Ubuntu MATE start)
Then:
- activate network
- start a root terminal
- make drive writable with command mount -o remount,rw /
- install libmateweather1 and libmateweather-common (with apt-get install xyz)
- install ubuntu-mate-desktop
- reboot
Ready. Now i was able to log in again.
(This german article from ubuntuusers.de helped me at this steps)
Same problem here, with the same output from terminal when I run /usr/lib/mate-panel/clock-applet.
Sorry guys, I screwed up
I’ve just upload a correct build of libmateweather to the xenial-mate PPA, once it is build and you update, it will work. Very sorry for the screw up. I mixed GTK3 and GTK2 toolkits by mistake.
Hi Wimpy
Just updated with synaptic and everything works nice.
Thank you for the quick fix.
Bye
Hello Wimpy,
nobody is perfect
It’s working again.
Thank you!
I´m so glad…I can look at it all day!
Works like a charm!
Thank you!
The only people that never make mistakes are people that never try…thanks for the fix, the fix for the fix, and the fast response
Good it’s solved now
[quote=“Wimpy, post:92, topic:8435”]
[/quote] And 100% took ownership and in an extremely quick fashion supplied the remedy.
Contrast this with 'commercial software’
###Go team @Wimpy
Unfortunately today as I booted my laptop I couldn’t find the clock and date icons and it’s impossible to add them on the top panel. I’ m running 16.04 lts with MATE 1.14.1 . Any thoughts?
I’m sorry guys after the latest update everything is working fine. Thanks Wimpy!
Temperature now working in 16.10
Edit:
When first installed I had a weather forecast, now its no longer available
