The “15.04” is a bit redundant because I think this is a MATE problem, not a Ubuntu MATE problem …
Does anyone else find that the Weather Report applet doesn’t update on a schedule? I add it to the panel, set London City Airport as the location, it picks up the first update (20 or 50 minutes after the hour according to when this was done) … then doesn’t update afterwards even if the refresh interval is set.
The only way to update it is to force the update by changing the location momentarily then reverting it.
It is odd that I have been all over the search engines (including obscure ones like StartPage and Qwant) and found nothing about this, as it is so obvious.
