To be clear - I'm helping a disabled, housebound 70-ish friend whose PC has U/M 20.04.5 courtesy of yours truly.
He had not used the Webex desktop app in a while, and contacted me asking for help when it would not open/run anymore.
I tried opening it remotely with the same vacant results - either as his user or as admin.
The DEB comes from here:
I installed the latest version & it still did...nothing.
The command to open it is:
/opt/Webex/bin/CiscoCollabHost %U
Tried that via terminal to see if any additional info came, and none did.
Did some open searching & the results that I found either pertained to the older/limited method to use it via browser, or info for ~V16.04.
The Cisco 'help' pages were also quite useless.
Might anyone here have experience with getting this to open & run correctly, please ??
Thanks for any helpful replies !!
