What's the best way to recover when Ubuntu Mate freezes?
I have a "desktop" and haven't installed "TLP", so I don't think that's it. , unless TLP is installed by default on 16.04.
I think that I may have a faulty SATA cable connected to my DVD drive. When you first begin having screen freezes/lockups, you don't often associate your actions at the exact moment with the lockup - such as using the DVD drive.
When I was doing my recent research on ATA bus errors, several people mentioned tracking the problem down to a faulty SATA cable or a loose cable connection. So it got me to thinking - Yeah, I was using the DVD at the time of the last crash. So now I'm trying to remember if I was using the DVD at the time of the other crashes. I think there's a good chance that maybe I was. It's impossible to be 100% sure at this point.
I have a spare SATA cable. I'm going to switch that out on my DVD and go from there.
Jim
FYI: It is installed by default on 16.04 (by ubuntu-mate-desktop metapackage).
Even if the package description says "save battery power on laptops", TLP manages many other things (CPU frequency scaling related things, for example) so it's useful on a desktop as well. See the TLP website for more information.
systemctl list-unit-files|grep tlp
Hi Jim,
if you can, take out the DVD drive (I assume it is a tower PC) and check as to whether or not the jumper is set to "Cable Select" instead of Master or Slave?. :smiley:
The normal setting would be Master for a single drive or Slave if you have it sharing the same cable as your HDD!. :smiley: (Wouldn't normally be the case with a SATA cable though!). :smiley:
I'm coming up with a different scenario so let me run this by you:
My harddrive is partitioned like this:
sda1 - swap
sda2 - / (ubuntu-mate 16.04 with kernel 4.4)
sda3 - home
sda4 - extended partition
sda5 - backup partition for home partition
sda6 - ubuntu-mate 16.10
sda7 - not used at present
I use mate 16.04 as my main system because my primary interest is stability. I was having a problem with virtualbox crashing so I installed it in mate 16.10 on sda6. Everything worked fine. No problems. I thought I had all the conflicts worked out and it's a lot of trouble to logout and login to a different partition, so I installed virtualbox in my 16.04 partition on sda2. I was in the middle of installing Chessmaster8000 when all the above problems began. (I had previously installed it in the 16.10 partition with no problem.)
I'm thinking the problem may be some conflict with the 4.4 kernel. Even though fsck says that my file system is clean, when I boot up with a live USB and run fsck it cannot locate any partition other than sda2 - it says that maybe the others don't exist. Obviously something got scrambled in the crash.
I going to do a reinstall, but before I do, if there are any log files that may prove helpful, let me know and I'll send them to you.
Since Im going to do a reinstall, and my primary interest is stability, and I know there have been some stability issues with 16.04 and 16.04.1, do you think these issues have been addressed in 16.04.2? I would seem that upgrading to the new kernel might address at least some of the issues. Or should I go back to 14.04 until these issues have been resolved?
Thanks, Jim
HI Jim,
it may well be a kernel problem but I cannot really say, it is possible that upgrading the kernel may solve the problems for you, I am using UM 16.4.2 and don’t have any hardware problems on two different PC’s, one is a midi tower (HP Compaq Presario/1GB Nvidia GPU) and the other is a mini Packard Bell notebook with Intel GPU!. :smiley:
I know. That really wasn't a fair question.
I was reading Jay's comments Screen flickers twice every startup - #14 by Etamuk
I know that 16.04 was a huge upgrade and Canonical made a lot of changes from 14.04. While I know these things are eventually going to get "ironed out", in the meantime, I would really prefer a seat on the sidelines.
A tip for next time: you can list the partition tables of the drive with
sudo fdisk -l /dev/sda
to see if all partitions are recognized. It also shows important information like Disklabel type.
It would not be a bad idea to view SMART information of the drive and run the tests. A drive that's about to fail can cause all kinds of "interesting" problems. As for the logs: saving journalctl -b output (logs from last boot) to a text file on a usb stick could be a good idea.
Better to fix the freeze. If you had windows10 on your machine and replaced it for linux then switch on legacy support in the BIOS. Worked for me on several laptops
Thanks for the reply, I fixed the freezes months ago though. :slight_smile: I replaced Win7 on this machine. It was actually the nasty Bug #109051, which causes total freezes on computers using low end Bay Trail CPUs. I edited my grub config file as described here. One of the reasons I love the UM community is that the solution to this issue was written down on a common problems and workarounds page!
No more freezes, the only downside is that the computer uses somewhat more power since I disabled CPU power saving modes.
