Whee! I Finally Pegged My CPUs
I know this may be one of the goofiest posts in a while, but I just had an experience that left me wide-eyed.
I use Webmin as my server management tool. It's often the most resource-hungry program running on my computer (xrdp runs a close second) but since I have 2 x Intel(R) Xeon(R) CPU X5670 @ 2.93GHz, 24 cores I don't usually see much CPU utilization. Until today.
I recently decided (on the recommendation of some posters here) to migrate my media server from Plex to Jellyfin. At the time, I decided my directory and file structure could stand a little better organization, so I started moving scads of folders around, moving files from one place to another, disabled journaling on an HFS+ disk, and all the while kept Plex running while I set up Jellyfin.
Holy tachometer, Batman! I saw the CPU usage in Webmin running in the 75%-85% range, and at one time it spiked into the 90s, even touching 99% at one time! Rather than be alarmed (well, I was mildly astounded) I thought to myself, "Finally! All that CPU power is finally being put to use!" I even heard the server's fans kick in--now that's some CPU workload going on there!
It didn't last long (and I think it speaks well of Jellyfin to update its metadata as things change!). But it was fun while it lasted!
So cool !! :smiling_face:
If you want to relive that moment, this script will torture your cores for you :innocent:
#!/bin/bash
# Choose your processmonitor
monitor=htop
# processmonitor fallback
which $monitor &>/dev/null || monitor=top
# stderr output gets in the way, mute it.
exec 2> /dev/null
# Empty screen and start processmonitor
clear
echo -e "\nstarting $monitor"
xterm -e $monitor & monitor_pid="$!"
# Get number of cores
read _ _ cores < <( grep "siblings" /proc/cpuinfo )
echo -e "\ntesting all $cores cores\n"
# The CPU-burn function
Burning() { while : ; do : ; done ; }
# Starting
for (( x=1 ; x <= cores ; ++x ))
do
	Burning & cpid[x]="$!"
	echo "coreburner $x active, pid=${cpid[x]}"
	sleep 0.5
done
# Waiting
echo -e "\nhit a key to stop burntest...\n" ; read -s -n1 ; read -t0.1
# Stopping
do
	kill -9 "${cpid[x]}" && echo "coreburner $x killed, pid=${cpid[x]}"
	sleep 0.5
done
# Monitoring off
sleep 5 ; kill -9 "$monitor_pid" && echo "$monitor killed"
That's what I love about Linux geeks: Always finding creative ways to be useless! :joy:
there is Prime95 and stress-ng, they will peg the cores to 100%.
Yeah, but just maxxing out CPU without doing anything is like spinning one's wheels. It burns a lot of rubber but doesn't get you anywhere.
Do all of your systems have sufficient cooling to avoid hitting the Thermal Ceiling that pops the core panic shutdown?
Regrettably, my old system does not! :frowning:
(And I already added 2 fans blowing air into the chassis at the built-in vents!)
Early on after I built my server, I had an issue with temperature and fan control. I installed a utility, [ipmitool](How to Install IPMItool on Ubuntu & Rocky Linux) and built a few scripts trying to get the monitoring and fan activation I wanted. I now have a cron job that runs a check every five minutes, and activates the fans if the temperature threshold is reached
#!/bin/bash
# Script for checking the temperature reported by the ambient temperature sensor,
# and if deemed too high send the raw IPMI command to enable dynamic fan control.
# Requires:
# ipmitool – apt-get install ipmitool
# slacktee.sh – https://github.com/course-hero/slacktee
# IPMI SETTINGS:
# Modify to suit your needs.
# DEFAULT IP: 192.168.0.120
IPMIHOST=192.168.1.199
IPMIUSER=root
IPMIPW=xxxxxx
IPMIEK=0000000000000000000000000000000000000000
# TEMPERATURE
# Change this to the temperature in celcius you are comfortable with.
# If the temperature goes above the set degrees it will send raw IPMI command to enable dynamic fan control
# MAXTEMP=27
MAXTEMP=31
# This variable sends a IPMI command to get the temperature, and outputs it as two digits.
# Do not edit unless you know what you do.
# TEMP=$(ipmitool -I lanplus -H $IPMIHOST -U $IPMIUSER -P $IPMIPW -y $IPMIEK sdr type temperature |grep Ambient |grep degrees |grep -Po '\d{2}' | tail -1)
TEMP=$(ipmitool sdr type temperature | grep Ambient | grep degrees | grep -Po '\d{2}' | tail -1)
if [[ $TEMP > $MAXTEMP ]];
  then
    printf "Warning: Temperature is too high! Activating dynamic fan control! ($TEMP C)" | systemd-cat -t R710-IPMI-TEMP
    # echo "Warning: Temperature is too high! Activating dynamic fan control! ($TEMP C)" | /usr/bin/slacktee.sh -t "R710-IPMI-TEMP [$(hostname)]"
    # ipmitool -I lanplus -H $IPMIHOST -U $IPMIUSER -P $IPMIPW -y $IPMIEK raw 0x30 0x30 0x01 0x01
	ipmitool raw 0x30 0x30 0x01 0x01
	touch /tmp/temptoken
  else
    # healthchecks.io
    # curl -fsS --retry 3 https://hchk.io/XXX >/dev/null 2>&1
    printf "Temperature is OK ($TEMP C)" | systemd-cat -t R710-IPMI-TEMP
    # echo "Temperature is OK ($TEMP C)"
    if [ -f /tmp/temptoken ]; then
	/usr/local/bin/R710-IPMIStatic.sh
	rm /tmp/temptoken
    fi
fi
