When mate@pi2 encounters unexpected power failure...HORROR
when mate@pi2 encounter unexpected power failure,even after fsck,many files still been corrupted :frowning:
(i don’t thinks it is tolerable)
is there any better solutions on mate@pi2 ?
mount -o barrier=1 /dev/sda2 /root
Power is the Achilles heel of the raspberry pi. Make sure you using a a power source with at least 2 amps @ 5v
