if the left pane is revealed (under view menu)
There should be a "Bookmarks" section.
(Ctrl+B gives you editing on this)
To set a bookmark, navigate to the site you want to bookmark, and press Ctrl+D. You will be able to edit the displayed name of the bookmark, and it will appear under "Bookmarks" on the left pane.
