Hello,
Am running Ubuntu MATE 16.04 but have also ran into this issue in the past simply running Ubuntu. What happened is: I pressed a key and now I am stuck with a terminal screen that will not go away (in MATE Desktop). I would further add that this terminal screen does NOT have any close buttons nor can I resize/move it using my mouse.
This is fairly annoying as pressing CTRL+D to close it just refreshes the CLI prompt and this spawns on my 2 desktops. The only positive thing that I was able to do was unmaximize it using F11.
A note worthy to mention is that my default terminal is Terminator and that instance I am having trouble with is NOT it (Hence it wasn’t started using CTRL+ALT+T).
I feel kind of stupid having to logoff to fix this, did anybody ever ran into that issue and was able to fix it?
Thanks,
DLS
PS: I would add a screenshot but it seems that I am also too dumb to figure out how to attach one
