Before blaming Caja (or any other process), you might want to try running the following script to monitor how much CPU is being consumed, in general, or, if you prefer, for a single specific process.
The command line format would be of the form:
OS_Admin__MonitorUsage_CPU.sh --mincpu 1.0
or the following form if you only want immediate reporting on one specific process:
OS_Admin__MonitorUsage_CPU.sh --mincpu 1.0 --watch firefox
The below script is currently hard-coded for a 60 second interval between reporting scans.
Script [OS_Admin__MonitorUsage_CPU.sh]:
#!/bin/sh
doIgnore=0
while [ $# -gt 0 ]
do
case $1 in
"--mincpu" )
minCpu=$2 ;
shift ; shift ;
"--watch" )
command="$2" ;
echo "command => ${command}" >&2
shift ; shift ;
"--ignore" )
doIgnore=1
shift
echo "Invalid option specified on command line. Valid options: [ --mincpu {real_number} ] [ --watch {process_basename} ]\n" ; exit 1 ;
esac
done
if [ -z ${minCpu} ]
then
minCpu=2.0
fi
echo "minCpu => ${minCpu}" >&2
while [ true ]
do
now=$(date '+%F_%H:%M' )
ps -eo pcpu,pid,user,args | sort -r -k1 |
if [ ${doIgnore} -eq 1 ]
then
### This logic to filter out cases reporting [kworker*] [jdb2*] and similar
awk -v pat="^\\\[" '{
if( $4 !~ pat ){
print $0 ;
else
cat
fi |
awk -v pmin="${minCpu}" -v pref="${now}" '{
proc=$4 ;
cnt=split( proc, cmd, "/" ) ;
if( $1 >= pmin ){
printf("%s| %s |%s\n", cmd[cnt], pref, $0 ) ;
sleep 60 ;
done |
if [ -n "${command}" ]
then
grep "${command}"
else
cat
fi
Once started, that will run endlessly ... until you kill the process. The output will look like this:
minCpu => 1.0
firefox| 2025-09-12_15:55 | 2.4 3493 username /opt/firefox/firefox
Xorg| 2025-09-12_15:55 | 1.7 1374 root /usr/lib/xorg/Xorg -dpms -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
mate-multiload-applet| 2025-09-12_15:55 | 1.1 2416 ericthe+ /usr/lib/mate-applets/mate-multiload-applet
firefox| 2025-09-12_15:56 | 2.4 3493 username /opt/firefox/firefox
Xorg| 2025-09-12_15:56 | 1.7 1374 root /usr/lib/xorg/Xorg -dpms -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
mate-multiload-applet| 2025-09-12_15:56 | 1.1 2416 ericthe+ /usr/lib/mate-applets/mate-multiload-applet
firefox| 2025-09-12_15:57 | 2.4 3493 username /opt/firefox/firefox
Xorg| 2025-09-12_15:57 | 1.7 1374 root /usr/lib/xorg/Xorg -dpms -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
mate-multiload-applet| 2025-09-12_15:57 | 1.1 2416 ericthe+ /usr/lib/mate-applets/mate-multiload-applet
firefox| 2025-09-12_15:58 | 2.3 3493 username /opt/firefox/firefox
Xorg| 2025-09-12_15:58 | 1.7 1374 root /usr/lib/xorg/Xorg -dpms -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
mate-multiload-applet| 2025-09-12_15:58 | 1.1 2416 ericthe+ /usr/lib/mate-applets/mate-multiload-applet
firefox| 2025-09-12_15:59 | 2.4 3493 username /opt/firefox/firefox
Xorg| 2025-09-12_15:59 | 1.7 1374 root /usr/lib/xorg/Xorg -dpms -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
mate-multiload-applet| 2025-09-12_15:59 | 1.1 2416 ericthe+ /usr/lib/mate-applets/mate-multiload-applet
firefox| 2025-09-12_16:00 | 2.4 3493 username /opt/firefox/firefox
Xorg| 2025-09-12_16:00 | 1.7 1374 root /usr/lib/xorg/Xorg -dpms -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
mate-multiload-applet| 2025-09-12_16:00 | 1.1 2416 username /usr/lib/mate-applets/mate-multiload-applet
firefox| 2025-09-12_16:01 | 2.5 3493 username /opt/firefox/firefox
Xorg| 2025-09-12_16:01 | 1.7 1374 root /usr/lib/xorg/Xorg -dpms -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
mate-multiload-applet| 2025-09-12_16:01 | 1.1 2416 username /usr/lib/mate-applets/mate-multiload-applet
The output format is geared to being able to filter, after the fact, for a particular command. Then, when that is needed, you can strip off the first column and get a record of usage reported with timestamp every minute.
If you saved that output (without --watch) to a "logfile", you could then extract just the values for any one of the commands using the following syntax
grep '^firefox|' logfile | cut -f2- -d"|"
to get a report that would look like this:
