The disk is mounted as '/media/JD2' instead as '/media/username/JD2'
This means:
- root owns the disk
- you do not own the disk as user
- you can not write to it because you don't own the disk.
Try to write something as superuser:
echo testing123 |sudo tee /media/JD2/testing456
read it back:
sudo cat /media/JD2/testing456
check your mount options while it's mounted
mount |grep sdc
This should get you something like:
/dev/sdc1 on /media/username/JD2 type fuseblk (rw,nosuid,nodev,relatime,user,default_permissions,blksize=4096,uhelper=udisks2)
Make sure it contains 'rw' and 'user'.
This is what the 'man' file has to say (man mount
Non-superuser mounts
Normally, only the superuser can mount filesystems. However, when
fstab contains the user option on a line, anybody can mount the corre‐
sponding filesystem.
Thus, given a line
/dev/cdrom /cd iso9660 ro,user,noauto,unhide
any user can mount the iso9660 filesystem found on an inserted CDROM
using the command:
mount /cd
Note that mount is very strict about non-root users and all paths spec‐
ified on command line are verified before fstab is parsed or a helper
program is executed. It's strongly recommended to use a valid mount‐
point to specify filesystem, otherwise mount may fail. For example it's
bad idea to use NFS or CIFS source on command line.
For more details, see fstab(5). Only the user that mounted a filesys‐
tem can unmount it again. If any user should be able to unmount it,
then use users instead of user in the fstab line. The owner option is
similar to the user option, with the restriction that the user must be
the owner of the special file. This may be useful e.g. for /dev/fd if
a login script makes the console user owner of this device. The group
option is similar, with the restriction that the user must be member of
the group of the special file.
So, back to your attached picture, if you click on the 'gears' icon and then select 'mount options' you should see the mount options in the 4th input-field. Make sure it contains 'rw' and 'user' and all should be fine.
